Help Required Old Satellite Positioner
Picked up this positioner up off Gumtree for a fiver, sadly it is missing its remote and have no clue to who the manufacturer was.
It says AKITA on the PCB but that is it. Any ideas as to who made it so I could perhaps get a harmony to work with it.
I need to clear the software limits, but cannot, tried every button sequence imaginable Grrrrr
Terryl
Custom built PC
I think you have the dish motor interface unit for a two part system, did a tuner come with it?
As there is a jack marked "TUNER", there may have been a separate satellite tuner that would display the menu for this unit, this may be what is missing for a remote.
"AKITA" looks to maybe be the PCB manufacture, it does not come up in my manufactures list.
No stickers on the bottom???
And the large IC chip number/manufacturer info may help, can you get a close up of that?
I had a similar postioner many years back that used the the 'tuner' port to talk to I think were Pace receivers so you could operate them from the receiver instead of the remote that came with the unit, a bit like an older version of what a Diseqc V Box does now.
You can operate them standalone too, if I had the remote!
Looks like the big chip was made by Temic??
I might know who stole the idea.
Can you take off the stickers on the ics and post imagery ?
Reminds me of the two-part NEC 5000 system I had in the early 90's - so it probably dates from the late 1980's.
Terryl
Custom built PC
Ahhh......Temic was bought out by Atmel years ago, no way to trace it down now.
 https://www.elnec.com/en/support/ic-logos/manufacturer-description/?manuf=Temic+Semiconductor
There may be something as to a manufacture's name under the main PCB, but you would have to remove it to see. (guessing)
You sleuth
Thanks for the replies. Will have a look at taking the PCB out to see...
Says 'Made in Europe' on the bottom of the unit...a great help!
Certainly a beeffy unit, hardly breaks a sweat moving the 1.8!
Terryl
Custom built PC
With that nice massive toroid transformer it should move a 20 footer.
And that IC with the #67 on it is an eprom, it holds the firmware.
Terryl
Custom built PC
Terryl
Custom built PC
I don't see a driver chip for an IR remote, but it could be on the front panel PCB.
dreambox1959
46.3N-4.3E-FRANCE
france
can you read the eprom ? if you can i can dissasemble it and maybe fix for a remote .
i need a picture of both faces of printed board.
best regards
best regards
Thanks for your trouble, but some of my receiver remotes were operating some commands which was causing me some problems. I only use it manually with the buttons to move my incline jack so don't need the remote control now.
