On The Edge (26E MBC problems)
Chesters
Fortec Star Zeta Receiver, Fraccaro 85cm motorized Dish
Lincoln UK
Hi Guys, Is there any way to increase my signal quality? I am just managing to get MBC on Arabsat at 26.0 degrees east and when I get it the picture is good but if the wind gets up I tend to suffer. Dish is a Fracarro 85cm dish with a Maplin twin output Lnb sat on a Moteq 2100 motor, reciever is Fortec Zeta.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The mbc transponder is very weak in the UK. If the wind is effecting it, maybe you need to adjust the azimuth position slightly. The best way of improving the signal is to get a bigger dish.
Robbo:)
satelliteman
Good choice of dish :D :D
As the Mbc beam on 26e is weak, if the dish moves a fraction you losing it. I have a similar problem with rain fade as I'm sure most do. There's not much margin for error with this beam/Tp. A better LNb may improve the situ. Is the dish very exposed?
SM :)
Chesters
Lincoln UK
Yes unfortunatly it is prone to wind, I'm just wondering if a more rigid mounting might be a good idea.
satelliteman
Ah.... tell me you haven't got it on a 'L' Type Bracket? :D
Chesters
Lincoln UK
When you say an 'L' bracket what do you mean? The thing that I have fixed to my wall is a flat plate approx 15cm x 20cm with a rectangular tube mounted in the middle at 90 degrees and then the dish mount tube at 90 degrees to that. Is this a nono?
satelliteman
Yes, is that what you got ? :D
Chesters
Lincoln UK
Yep I'm afraid so. Ok then what should I be using?
T & K brackets with a length of steel tubing. Those L brackets flex too much - and have a nasty habit of shearing off in winter storms!
Chesters
Lincoln UK
Ok so T & K brackets, it is at this point were my lack of knowledge shows itself. Can you give me an example of such brackets and where to get them.
satelliteman
T&K fixings either 12 Inch OR 18 Inch. 2 inch steel mast in fine and fit the motor between the two.
Check the site sponsors in my signature for supply of brackets
SM :)
You can get T&K's from big DIY stores or maplins.co.uk.
wod
yorkshire
or people who fit tv aerials will have some and i'm sure they would sell you a set of the brackets
satelliteman
At a reasonable mark up I'm sure:-lmao
guest poster
registered
I think you have done very well with that setup to get MBC... The Fortecs are not known for sensitivity either... I'd say you could gain a vital 20-30%+ with a much more sensitive stb and LNB... good cable is critical too..
Maybe the Fracarro is as good as they (the manufacturers) say...
:cool::cool::cool::cool:
