panasonic sky digi box tu dsb 30
sting
Visit site
hi people ive got a sky digital box it'll only work on astra 19.2 east via other channels . while on sky once it's found the listings it just witch's it's self off to stand by mode and when switch'd back on it do's the same any 1 know why
Hi Sting. has this box ever worked on 28.2 since you've had it and do you have a subscription card in it? If not, try doing a forced update (make sure that you are on 28.2 East first, then see if it does the same thing.
sting
Visit site
yes the dish is on 28 .2 e (sky) and working as ive tryd anther sky box on it and its fine
as for force'd update it wontupdate just stays on update screen and all lights at front stay on perid
Seems like an odd fault, how long have you left it on the update cycle?
PS. do you have a card in it?
Try holding in the backup button while you switch off and disconnect Sting, then go through the standard forced update procedure, leave it on as long as it needs.
dishdoctor
Hmm, now what seems to be the problem?
Torreblanca ,Malaga
Leave it on as long as it needs............now there is a highly technical answer...........3 weeks later,do you think it needs any longer as the updating software message has burnt into my 42inch lcd screen............
Sorry Brian, should have qualified it with "within reason":)
PS. These cheap old tellies;)
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
Or you could switch off tv now and again :rolleyes:
dishdoctor
Torreblanca ,Malaga
I would not be where i am today if i went around turning my telly off willy nilly,when you buy a television licence the only wat to get value for money is to leave BBC on 24 hours a day.....................
Zorba
So,you're the one that bought the tv licence?
S'pose somebody had to,or else we wouldn't get to watch the likes of antiques roadshow and songs of praise.
