PAS 10 in Finland is it possible ?
satbuster
I 'm new in this forum, looking for some help. I have Technisat CIVA digibox with in built Viaaccess cam and one free CI slot with 88cm dish and 0.6db lnb. I live in Helsinki(Finland). I can recieve Hotbirds clearly just need help to tune my dish for recieving PAS 10, which many think not possible to get in here. Anyways i saw some places selling Tensports channel card, thought why would they sell the card if people cann't receive satellite.
Thanks in advance for help,
cheers
SB
pas-10 will be virtuyally on your south easter horizon, so unless you have an ideal horizon (absolutely no trees hills buildings etc) out to the south east you can forget it. There was some discussion about this a couple of weeks ago - I think the consensus was ground noise was likely to be aproblem, & anyway you would need a a BIG dish, ISTR 5m was mentioned, although it will be in the archives if youwant the exact details.
Likvid
Stockholm, Sweden
Helsinki about 32dBW in that map, 4.5-5.0 meter dish maybe.....
Actually Helsinki is on the border of the actual footprint (right on the border). The satellite is probably at an elevation of 3-4 degrees in the city, so as to why the cards are on offer, I cannot give an answer as the signal would be available only to earth stations.
Likvid
Stockholm, Sweden
According to the look angle calculator the satellite would be at 12.7 degrees elevation in Helsinki, pretty normal.
I used to receive Panamsat at 45 degrees at my location with elevation at 1.5 degrees, there was alot of ground noise.
Not according to that map its not, but if its 12 degrees then reception should not be a problem , assuming the correct dish size is used.
satbuster
I had calculated using given angel calculator on panamsat website.
Azimuth = 132.400971
Elevation = 12.717566
I have triax 88cm dish. i get extremely good reception of hotbirds.
Could some one tell me what are the parameters for this satellite.
e.g. symbol rate, Polarization, freq. etc.
