Power Draw From Jaeger 1224 Motor ?
Can anyone please advise me of the power draw from a Jaeger 1224 motor when moving a dish? Also, are there power draw spikes when it commences moving a dish?
I was testing a fairly old 1224 with a couple of old Echostar receivers (DV7000 and LT8700) and noticed that the motor cable seemed to be getting quite warm when moving the dish East-West a good few times. Is this normal or could it be that the old Jaeger 1224 is drawing excessive power or my motor cable is not so good?
Draws about 35W at the input side of the V-box (240V) while the motor is moving. So if the V-box channeled all that power to the motor you are looking at about 1A (at 36V).
I am not using a V-Box with Diseqc, I am using the internal 36v positioner of the DV7000 and the LT8700 receivers, will this add to the power draw or will it be the same? Does anyone know what the power draw is when using a receivers 36v internal positioner rather than a V-Box linked to Diseqc?
It's the same. Power is drawn by the motor and if the receiver/positioner can supply it, it will. A receiver will not give more "power" to the motor than it needs, as long as the voltage is 36V.
So it would be around 1 amp current, 35W power according to the figures from "Huevos".
Hmm, I cannot see why that would make the motor cable get warm, it's quite a low draw, I think I need to try some other cable?
Thx for the input so far, most appreciated
What would the new cable do? If too much current was flowing through the cable, they would get warm - don't worry about currents and cables, I really don't think that's your problem.
In fact, maybe it's normal for it to get warm? It's driving a huge, heavy dish, so I am not really surprised.
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
The cable gets warm due to ohms law.
It's resistance is too much for the amount of current flowing, hence it gets warm. You are dissipating power into it.
You need thicker cable
Pretty sure that cables are not supposed to get warm.
satelliteman
What cable are you using?
Sorry, I misread the original post. I was thinking that the motor was getting warm, not the cable. Yes, you need a thicker cable...
Apologies for the confusion. (I blame the new font on this forum :p)
wod
yorkshire
I've never checked to see if the cable was warm but I've used a 4core cable with thicker wire for the motor power and thinner wire for the motor sensor with my 1224.
It's the vbox, I have noticed that gets warm as I have my receivers stacked with spacing between but still kicks out heat.
Thx for the replies, I am using a piece of 4 core cable that I found in the loft with blue, orange, white with orange stripe and white with blue stripe cores but I am not sure of the spec. It's not the same cable that I have on my main motorised dish which is the old flat ribbon cable from years ago for multi sat with polariser, motor and LNB cables in separate sheaths of the flat ribbon.
The cable I am using for this test with the old 1224/dish/decoders is just a "normal" piece of black 4 core cable with all cores the same diameter. Is that no good and can anyone let me know what cable I should get if it is no good? I am not sure if this stuff is OK for outdoors, nobody seems to make the old 4 core with thicker cores for the motor and thinner cores for the sensor?
Do you know what gauge it is? Or maybe a picture of the wire?
I am not sure of the guage, it might be 0.5 mm or less, actually, I got the colours wrong, it is orange, blue, white with orange stripe and white with blue stripe, I was getting confused with another bit of wire I was thinking of buying. I will upload a pic if I can get one onto my PC
Orange, Blue, White & White with Strip sounds more like a signal cable of some type (phone etc.) rather than something that is also intended to carry even modest appliance currents.
Alarm cable perhaps?
OK, got a picture, I cut a section off the cable and have attached it.
If the cable is no good can anyone recommend something I should be using suitable for a Jaeger 1224 motor connected to a 36v internal positioner on on LT8700 or DVR7000 receiver? I assume I need a grade of cable for outdoor use as it will be covered with a few inches of shingle for part of the run?
Thx
To be honest, I use a very similar but multi-braided one :-ohcrap :blush: But mine drives a jack arm rather than the whole polar mount (probably takes less power).....
I'll leave this one to the pros.
@moonbase: Well I can't positively ID that (although the Captain might be on to something), but it doesn't look unduly flimsy, as it happens.
Nevertheless, you need to consider what Robbo said earlier about I² × R (Heating losses as derived from Ohm's Law for a conductor of resistance R) >> "Bigger" cable = lower R = lower I² × R for a fixed I (where I = Motor Current)
It is unlikely that the motor is drawing more than it's design current, so really it must be that the cable isn't man enough for the job.
On the assumption that the cable is not up to the job can anyone please provide a link to a suitable cable type or let me know what I should use?
