Power Draw From Jaeger 1224 Motor ?
wod
yorkshire
you could probably get away with using 4 core mains cable if its going to be in a weather proof casing.
@moonbase: Well, it depends upon whether it is a real problem or not ...........
eg I fitted an 8.5Kw Electric Shower last year: I sized the cable using BS7671 (IEE Wiring Regs) tables governing not just the maximum current, but also the duty cycle (how much and how often it would be passing that current) and the nature of any insulating materials (walls, timber, rockwool) etc. that it might pass through or be covered by.
The cable gets vaguely warm to the touch (Outer insulation!) after 5 minutes use.
That is not a problem.
And that's after following closely worked and well-understood guidance - in your case, the voltage and the risks are rather less and the consequence of occasionally warm cables (not hot!) is not likely to be significant and the selection of cable size can be less scientific - BUT following the Motor Manufacturer's advice is a good idea. What does that say?
@wod: Yes, a lightweight "mains" cable would be fine, subject to environmental conditions.
Riverblue
Near Brighton
Hi there, I agree that your cable looks like an alarm/communications cable and is not really suitable for what you want. Ideally you want a 0.75mm 4 core pvc flexible cable (stranded core) rated at 6amps. This would be more than suitable except when the cable run is very long (30m+) then due to the increased resistance I would suggest that you go for 1.0mm, rated at 10amps. Black rather than white because black cables are uv rated for external use (my local wholesaler, who I trust, informed me so a while ago). These will be ok outside, they can be clipped/cable tied to surfaces but if going on/underground then encase in a protective conduit. Your local? electrical wholesaler should be able to provide with all that you need/advice. :)
pride21
Sandown Isle of Wight
hi moonbase i have used the jaeger 1224 for quite a few years i am using ordinary 3 core lighting flex and had no trouble with it.
