power supply technosat
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
mnadeem said:
hi
where can we buy new power supply for technosat receiver in europe
I cannot answer your question but anyone that could would have difficulty!!!
Where exactly in Europe ??? it's an effing big place if you look at a map. Also definitions for Europe change depending on certain conditions. e.g. For travel insurance purposes Israel is in Europe geographically it is in the Middle East.
Low Profile
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
Look at the capacitors in the power supply, if any of the tops are bulging then replace them. Also, If they are for example 16V caps then change them for 25V caps.
