Problem with My Thearte.
J
jagga
Likes
england
#1
Im having a problem with My SS-1 Card When I install My card Windows xp cant find the card.I have gone to Had New Hardware and I can see the Card but is has an Explanation mark next to it, but it doesn;t give me the option of installing a Windows based Driver.I've even got the new Driver 917 to support the card, when I install the 917 Driver it install's fine but when I check through Device manager the card is not available.
Hoping somebody can help,
Thanks,
Jagga
K
Koala
Wasn't sure if you had solved your problem yet ... I had the same problem and solved it. I thought XP would install the card for me, it does everything else and works fine, I was wrong, with the PCI cards I found out you have to install the software disc that comes with it. Once I installed the disc .. everything was fine.
J
jagga
Likes
england
#3
Koala,
Thanks for the message m8 I've been setting up my brothers machine, so I havent really got around to having another go yet'could you pm me the drive or even the disc that came wth your card,
Thanks again,
Jagga
