Problems Condensation on inside of channel master feed horn
R
Rd100
Problems Condensation on inside of channel master feedhorn window of my new cm feed horn on my 1.8m channel master the feed horn has only been on there a few days but i did notice it is easy to pull the feedhorn window cover on and off, Any one thing it would be safe to glue it on with some pvc silicone to seal it
ouagadougou
Likes
2m NERA Prime Focus Dish for C/ku Bands, DM500, SkyStar2, Technomate 5500CIP, Force 1122.
Stockholm & Windhoek Namibia
#2
If you keep the glue off the window face and outside the feedhorn then it should be ok but you could get loss otherwise also depends how much and what type of glue as well.
R
Rd100
Yer i know that i have just repaired it and will see how it goes now
2cvbloke
Bulbs need shelter too...
Likes
1,695
Near Pontop Pike, Co. Durham
#4
Don't see what could go wrong with silicone sealant on the feedhorn cap, I've pulled enough LNBs apart with silicone sealing up the cap... :D
