problems descrambling channels
aliban
I have a dreambox 7000s. I downloaded the hydra dragad image. I donwloaded the mary's softcam.key file and did not manage to make the french channels work. (france2-3-5, multivision). I used the remote control to do this it did not work, I use ftp, untar, dos2unic to remove the ^M characters and nothing helped. I started xcamd manuall... stil can not descramble.
Now my questions are as follows:
1- I am using xcamd plugin, and downloaded few others. Now is one plugin enough or do we need to use a specific one depending on the channels?
2- For the keys, the xcamd module seems to erase the keys.txt file, is this normal?
3- If I use aany deamon, how can we enter the keys manually? I know that using vi can do, but how can I know the format...
Best regards,
Aliban
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
If you have Marys then set the default sCAM to NewcamD.
If you don't have NewcamD download the latest version from the control panel.
peloquin
Yeah Newcamd or Radegast should get u most stuff that is currently viewable, make sure u update control panel aswell
