problems vz my theatre
C
coloureye
Likes
1.2Cm dish, Motorized, TM1500CI+,dragon cam,SS2....
North england
#1
i've got ss2 and my theatre installed
found the tips given by BGstick
install the Y*nkse.dll and then the softcam...
most channels works fine(just like a dragon cam isn't it?)...
but still sth confused
wut is Capi0.8 and Emunation1.1a... if i got those files,
which folder shall i put it in (mytheatre system)
thx
O
Old Geezer
Likes
Deepest South Wales
#2
Hi Coloureye,
As far as the yankse plug in goes , it seems to have been replaced by S2Emu and CAPI.
When You get a new emu like Capi (or S2) , only the DLL file goes into the My theatre/MDPlugins folder , and the other files go into the root directory (C:program files/My Theatre).
You will also need a softcam.key file which also goes to the root directory.
It's generally accepted that You should only use 1 Emu at a time , so remove the other/s from the MDPlugins and keep them safe (on the desktop for example).If You use more than 1 at a time it slows the decoding down and may cause problems.
Check out the links on the forum for places to get the latest Emu or try a google search.
As far as Emunation goes , I couldn't say as it's not one I,ve used before.
Stick (BG) is currently doing a bit of testing on the latest files around and will no doubt post any results that He gets.
Hope that helps You,
Cheers for now,
Old Geezer.
D
d_lamer2003
Likes
skystar 1 + Motorised dish.
malta
#3
Old Geezer said:
Hi Coloureye,
Cheers for now,
Old Geezer.
Ok I know this might seem a stupid question, but in under the mytheatre folder there is no MDPLUGINS folder but PLUGINS folder and when I put the capi.dll in the plugins folder and the key file in the root, still the emulator didnt show in the plugins list, when I start the program again.
C
coloureye
Likes
North england
#4
thanks so much, Old Geezer
it is working now.
but some new problem pop out,
I just put both emukeys and softkeys into the root folder
when i m trying some scrambled channel(like cannl on hotbird), it is said systerm error and mytheatre will be closed
is that like u mentioned,
I should only use 1 Emu at a time ?
to d_lamer2003,
google mytheatre and download the full version of 2.76
there should be a folder name as MDPLUGINS
good luck
O
Old Geezer
Likes
Deepest South Wales
#5
Hi again CE,
I suspect that the problem with MT shutting down is a key problem , as it also happens on my computer as well.
I don't think that canal can be opened using either of the 2 emu's mentioned.Perhaps someone with a bit more knowledge can let You know if it's possible.
If You try the emu's seperately , CAPI likes italian channels (S*y Max,Classics,Cinema1-3 & 16:9) , S2EMu likes the TPS channels (Multi & TPS).
You can always try the 2 dll's in the same folder but it may cause problems.
Have fun,
Cheers ,
Old Geezer
D
d_lamer2003
Likes
malta
#6
it is working now.
to d_lamer2003,
good luck
I have a newer version 3.25.1 and there is only a plugins folder, and not MDPLUGINS. :(
I have only succeded in making s2emu work,but the other soft emus, didnt succeed to make them work :(.
BGonaSTICK
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#7
CAPI works well, but you need the extra keys.bin file.
Both D+ and Sly Italia changed keys yesterday for April. Go get 'em!
STICK
D
d_lamer2003
Likes
malta
#8
I cannot get neither capi nor any other emu apart from s2emu to work with myTheatre on the myTheatre version :(.
BGonaSTICK
BGonaSTICK
Likes
Brighton
#9
CAPI.dll goes in the MDPlugins directory.
There should be nothing else in there.
Into the root directory (C:\Program Files\MyTheatre) should go the following files :-
keys.bin
EEP.bin
Ram.bin
Rom.bin
s2_hash_0064.bin
s2_hash_0065.bin
s2_hash_0070.bin
s2_Mt_0064.bin
s2_Mt_0065.bin
s2_Mt_0070.bin
seca2.cfg
That's all you need my friend. If you get the latest version of all these files, it will work.
STICK
