Prog DVB setup problems
D
drayman
Likes
medion 3.0ghz skystar 2, 88triax dish,Sg2100a motor
brum
#1
Hi Sir Bronking,
thanks to your guide triax 88, motek sg2100 is up and looking at 1w spot on watched canal+ HD preview,bbc world ect in (DVB viewer). Prog dvb is another matter downloaded (technisat driver v4.2.11) from happysat = 969 zip file. unzipped is 2x down bat files,ger 15136.pad file, Info text file, update exe file. I am asuming i would use device manager to update/change driver but when i try to open the driver 4211 folder i get error skynetsys not found. Is the little bu99er in the pad file(what ever that is ) or am i scratching the wrong tree! Bear
Likes
1,296
#2
Have moved this to the PC Card section, as you posted it in a howto thread by a member who hasn't been on the forum for 6 months. :)
S
sachithanantham
Likes
zenega
india
#3
hai i am new to this site, i am in india. I am using dishtv zenega receiver, recently they changed the new software so i unable to enter transponder and symbol rates for other networks. I need to use the same settop box for viewing channels provided by other networks. how can i access it? or want to change the software for my settopbox.. if possible please help me..
my email ID is: sachi*mail.com
thanking you
