progdvb & ss2 help
andy-gi
Visit site
hi guys,
i'm a NEW user of prgdvb with ss2 but a very experienced sat user!
my system is winxp amdathlon1000 256ram
and a 3,1motorized ch.mas. with echo3000
i installed succesfully ss2 and progdvb & yanksee & valid softkey(xamux)
BUT, the only enc.channel i managed to watch is bbcprime from 13e
and the showmonitor on this channel shows all the details!
when i go to other enc. channels e.g. sf2,ab1, et.c. i can't see anything
and the monitor stucks, it doesn't read anything!
i've been told i have to change the ecm&pmt of these channels.
so,all the channels i downloaded have wrong ecm&pmt and only
bbcprime has the right one?!
quit hard to believe! it must be something else!
also, i can't adjust the bright&contrast from the audio+video menu
i click on it, it comes up but it doesn't let me to adjust.
the reason i put myself in this "trouble" using the pc for satviewing
is to watch the 422 feeds. what do i have to do to watch them?!
the ss2 +progdvb can do that?!
please help
thanks in advance, andy
arraknid
First thing to do is install new drivers mentioned elsewhere in this forum, then try again.
Little Jim
Just north of London
Yep tried that...
Locked up.
Lost use of SS card
had to restore system
Is it me??:confused
If you are using Windows XP, then try MyTheatre, can be a little less glitchy, also try putting the SS2 in a different slot if you have one available.
Little Jim
Can I install more than 1 plugin at a time?
timdikine
i want to now haw many satelite i can watch in my contry moroco and olso the transponder
i have a Goldenintrstar 8001 premuam LNB 0.3 db . tink you
