Receivers with Hard drives
Pullet_Surprise
York's
Some of the receivers that are currently on the market have digital storage facility via a hard disk. Are these drives the same as a PC hard drive?
Pete.
They are
Seagate is the most common Ive found
receivers will howver have a 'void if removed' sticker somewhere to prevent you from doing a DIY job on the replacement
Well are you going to take the lid off and play around ?
Would love to have the ability to run the laptop screen directly off the USB port of the receiver if one can find how to decrypt the info on the hard drive as its recorded. If it can be played back through the normal outputs why not the USB ?
Pullet_Surprise
York's
CH,
Most definetly. I didnt know any of them had a USB port, I only really looked at the Echo' 5000 dvr, which seems quite unremarkable apart from its high price tag. If the HDD is easily removed and replaced as you say, then this opens thing up. I was thinking that perhaps this may eliminate the need for a PC card to playback to, maybe some cleverly designed software may do the job via serial port on the receiver to a port on the pc.
I believe one will have the same problem as I have with a serial port providing unencrypted info for playback purposes
The video and audio data is retrieved when the SCART and RF outputs are used, so there must be another process in operation when playback of recorded material is done
Never seen Get Carter - is it worth taking out on video ?
Pullet_Surprise
York's
If you like 70's gritty Northern drama and Michael Caine then its a must. ;)
Will try and find it on satellite
2old4this
Honorary Admin
Cloud Cuckoo Land
The echostar 5000 does not have a USB port but the 7000 does. I own a 7000 and am very happy with it.
In Echostar's case, there is specific steps taken to prevent direct access to the data on the HDD (and there is also no digital-video-out port). This is due mainly to pressure from the providers and owners of encryption systems.
The formatting of the harddisk is also proprietory - i.e., replacing it with a larger-capacity general PC unit will not work.
2old
