receiving hotbirds on 6 feet dish in Pakistan
gul_the_bull
Likes
skystar 2 pci dvb card
6 feet metal casted dish with full c/ku support.
Pakistan
#1
Hi I am getting hotbird on a six feet solid dish in mianwali Pakistan many of my folks are receiving it on 3 meter dish please note that LNB must match with the 6 feet dish
Likes
8,221
Skybox F3
Excellent stuff!
This is the sort of info that should be in the general fringe reception section -- so I'll move it there. :)
wod
Likes
235
yorkshire
#3
nice one, how much off hotbird can you recieve ?
gul_the_bull
Likes
Pakistan
#4
yes I am receiving all the channels of hotbird HOT234Kw and Hot006Kb beam (as on satcodx list )channels.It is very hard to adjust the dish and the LNB but I managed to do so after some mechanical alterations to the feed of the LNB as normal LNB are for OFFset dishes and we generally use prime focus deep dishes causing great signal loss
wiseguy4u
Likes
The frequencies of Hotbird you can receive on 6 feet fibre glass
dish in Pakistan are
10719
10775
10796
10723
11766
11804
11919
12169
12245
12654
12673
12692
gul_the_bull
Likes
Pakistan
#6
Well friends before I was getting HB 4 on six feet(180cm) dish and as the HB8 arrived the fringe reception has degraded and I am unable to receive valuable signals from HB8 on the same setup. Signal from other satellites are visible.Any body from Pakistan receiving signals of HB8 like 12692,12360 and others on any setup please reply
wod
Likes
235
yorkshire
#7
you was doing well to get hotbird on that size dish
think you may need to go bigger prehaps 2-3metre
