Remote Control Coms Question
remlap
remlap
Wales
I am about to buy a Technisat Skystar 2 2.6D card with remote.
Problem is I do not have a free coms ports ive checked ebay and there is many USB to RS232 but not RS232 to USB do these things exist and would it work if they do and where do I get one.
Cheers
remlap
remlap
Wales
Always trust the Aussies to have something I cant find on ebay.
Thing is will it work, ill wait and get the card first.
remlap
remlap
Wales
Hey Lancelot ive just purchased my skystar can you suggest any forums I can visit software wise, really all I want it for is MPEG 4:2:2 but still.
Also is it recommened to switch off the PC while removing the satellite dish cable.
Cheers.
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
I must admit I (nearly) always do with the SS1 and it's been fine for years.
Are you going to set it up this evening ??
L.:)
remlap
remlap
Wales
L.:)
Ive ordered it from Germany so its gonna be a few days yet.
Lancelot
Lancelot
Retired Mod
SS1.
South central
Yep , that's the bit that got me :-doh!
L.:)
remlap
remlap
Wales
Are Skystar able to do blindscans im under the impression theres some sort of 3rd party plugin that make them do it.
Cheers
Sir Bronking
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
1mtr dish & jaeger 99G 36v motor, with a superjack DP-6600. dvb-t aswell,in the process of setting up
cheshire,algeria
yes i'll root it out for u
Sir Bronking
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
here it is:)
remlap
remlap
Wales
Which software will this work with once ive got the card installed thats all really I need.
Diseqc 1.2 to move the dish, MPEG 4:2:2 decoding and blind scan.
Thanks for finding it for me.
Sir Bronking
Sir Bronking
medion
pentium4 3.2ghz
progdvb
skystar2 rev2.3
cheshire,algeria
:-doh! oop's sorry
quote from text
This toy is working ONLY with SkyStar2 Revision 2.3
my fault for jumping in
lancelot the man to sort you out
remlap
remlap
Wales
Ive purchased a 2.6D I think.
