jonny bravo
- Jan 1, 2000
Hi M8's,
Could some of you knowledgeable people help me out.My remote has a few buttons that don't work i.e when I put telext on, the button to take it off is worn and the only way I can get it off is to turn the set off then back on. I've taken the remote apart and the rubber pads behind the numembers are worn. I could remedy the problem by sticking very small pieces of aluminium foil on the pads, but I wounder is there a special(paint)to redo the pads? I just hope my question makes sence.
Any help or advice appreciated.
