• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
Replacement mount for dish
Edinburgh, Scotland
I've replaced a Sky dish with a Raven Gemini 90cm dish with three LNBs, and all went fine - apart from the mounting bracket. It's a bit small. The offset from the wall is 400mm, which is fine (ideal, in fact) but the tube is about 30mm diameter - the Gemini needs 38mm to 60mm. So right now it's padded out with duct tape - not ideal, but it's working meantime... but I do get worried when the wind gets up.
But obvously I'd like to replace the mount with something a bit thicker and tougher - probably a 2" tube bracket. But I'd still like the offset to be 400mm if at all possible. Anyone got any recommendations for a bracket to suit? The ones I've found appear to be either 350mm (two short) or 550mm, which is long enough that I'll probably have to run a new cable or two.
