Running SKY+ through a laptop
N
nwcpn
Want to run my sky+ box through my Sony Vario Laptop when abroad.
The laptop has 2 PCMCA slots
3 USB ports (2.0)
is it possible to convert the signal from the Sky box to go through the above ports?
many thanks in advance
nigel
Rod Hulls Aerial
Rod Hulls Aerial
The Lord Lucan Moderator
Sky Star 2 - Motorised
Errr.. thats it.
The cold and foggy Yorkshire coast..
Well you could get a USB TV Reciever (like a USB wintv unit) and play your sky box through it, in effect your just making your laptop into a TV screen, but don't forget to take a dish and digital LNB and also ensure your in the Astra footprint !!
peter in the bus
peter in the bus
KENT
I have a hauppauge WintTV2000 USB device. It connects to your sky box via a RF (coax) cable or a S-video cable, and then into your laptop via USB. It works fine on small screen, but for full screen resolution it leaves a lot to be desired. Are there any really good devices for capturing sky digital to watch on a PC or laptop, or is this (the Hauppauge) as good as it gets???????????
Peter in the Bus
