S2Emu 1W Problems
D
damhy
Kent
Since the new key 21 came out there have been getting problems with S2Emu 1.8 and Yankse with the 1W channels. S2Emu reports an invalid signature on the PPV channels. The result is with both s2emu and yankse, that the picture decodes a bit, then freezes, then decodes a bit, freezes, etc.
Yankse has the control word and then at the point of freezing it changes to all 01's, reverting back afterwards.
Wondered if anyone else experiences this, or has a solution.
BGonaSTICK
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Working fine here.
As the new key20 has already been uploaded (ready for a key change next week probably), what I would suggest you do is to remove the old (invalid) key20 from your s*ftcam file altogether. Also make sure you are on S2emu V1.08.
STICK
D
damhy
Kent
BGonaSTICK said:
What I would suggest you do is to remove the old (invalid) key20 from your s*ftcam file altogether. Also make sure you are on S2emu V1.08.
Very stange although S2Emu said 21 gave the invalid signature, when i removed 20, it now works fine. Very weird. Thanks for the suggestion.
BGonaSTICK
BGonaSTICK
Brighton
Np..............:)
Rod Hulls Aerial
Rod Hulls Aerial
The Lord Lucan Moderator
Sky Star 2 - Motorised
Errr.. thats it.
The cold and foggy Yorkshire coast..
At last.. one step closer to motorisation, I now have my new 1 metre dish pointing at Thor, motor will be set up on Tuesday, can someone point me in the right direction for what I need to do to get the "goods" on Thor ?
I've got S2emu and what I thought was the latest key but zip...
any suggestions ?
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
Rod Have a look in sleepy hollow :)
Rod Hulls Aerial
Rod Hulls Aerial
Errr.. thats it.
Ta, all sorted bar an odd problem with Ki*sk..
Getting a blocky stuttering picture despite having signal strength and quality in the 70's, even tried a different LNB and the same problem.
Using ProgDVB and S2emu (also tried Yankse) 2600Mhz Athlon 512 ram SS2 card.
Most other channels no problems at all, however cannot get Priv*te Gold either, scanning the transponder but nothing there..
Anyone else having similar problems ?
D
damhy
Kent
Yep Ki**k doesnt work with progDVB unfortunately. About time they fixed it really.
Rod Hulls Aerial
Rod Hulls Aerial
Errr.. thats it.
Odd really, works fine with DVBDream though.
Still cannot find Priv*te Gold though ?
D
damhy
Kent
Yep thats why I use dream and not prog.
Anyways PG is definately there after 11pm. Not for me though cos that transponders just a little too weak.
Yes, Private Gold is on the Eastern Europe beam, so you may not pull it in with a 1m dish.
