hello guys. i desperately need sum help with a samsung SFT-303. the receiver was loaded with the old 2000 software and i had to upgrade it with the new one. i downloaded two sofware versions from the official samsung corp site, one of the 2001 for europe and one of 2002 for middle east. since i live in europe i decided to upgrade the receiver with the european software. the upgrade procedure went ok, the receiver downloaded the software and as it says in the instructions it was supposed to reboot itself but instead it went off and wouldnt switch on. i plugged it out and in but it didnt help. the receiver was dead, showing nothing on the display. then i checked the instructions again and it is possible that this software didnt do for this receiver even though on the site they said it did, cos it turned out there is a difference in upgrade procedure between the two software versions. for the european it says:
Samsung Corportion Jan 18, 2001
Digital & Analog Satellite Receiver with built-in positoner (SADP-303)
Digital Satellite Receiver with built-in positoner (SDP-303)
Digital & Analog Satellite Receiver (SAD-303)
< Software Upgrade >
File Description
Samsung.exe : Host upgrade program downloadable via RS232C port
main.bin : Software data source file
Instruction.txt : Software down load procedure file
< Caution >
Do Factory Default of your receiver before upgrade.
Do Upgrade at DOS Prompt mode not Window mode.
Do not power off(Plug-Out) while doing Upgrade.
If you fail to upgrade, please do again from the top beginning.
Upgrade Procedure
* PC to SET Software Upgrade
Connect your PC and Receiver with twisted RS232C cable.
Pin 2 & 3 in RS-232C line should be twisted.
ex)
Set your receiver 'Factory Default' under 'User Installation' menu, and Plug-out / Plug-in the receiver power cord.
Power off your receiver. (Standby mode)
Type alphabet 'dnld' toward the receiver with using numeric keys on the remote control. Ex) Press 3 66 555 3 (dnld). You will see 'dnLd' displayed on the front display.
Note) In case you pressed wrong numbers, and 'dnLd' does not appear on the front display, please power on-off and try again. 'dnLd'will not appear until you finish typing all 4 letters.
Type 'Samsung' on the DOS prompt under the directory where the upgrade files exist.
Select your PC communication port COM [1] or COM [2]
Push ENTER Key on your PC and then Press OK button on the receiver remote control.
Download takes 4~5 minutes, and the receiver will automatically reboot when upgrade is done successfully. In case your receiver does not re-boot, plug out and in AC power code of the receiver.
Remarks - In case you fail to upgrade properly, DO NOT Power-off your receiver, and repeat from the beginning.
for the middle east it says:
Digital Common Interface Satellite Receiver (SCI-302/303)
Digital Common Interface Satellite Receiver with buit-in positioner (SCIP-303)
Digital Free-To-Air Satellite Receiver (SFT-302/303)
File Description
samsung.exe : Host upgrade program downloadable via RS232C port
* Before Upgrade your receiver, please do 'Factory Default' under User Insatallation Menu.
Upgrade Procedure
ex)
Power off your receiver. (Stand-by mode)
Type 'samsung' on the DOS prompt under the directory where the upgrade files exist.
Select COM Port speed 115200bps[1] or 57600bps[2] When your present(Slave) software version of your receiver is under V3.0, please select [1], and select [2] when it is over V4.0.
Remarks
i opened the lid and there is a small button on the motherboard, is it possible to reset the receiver to its default firmware or do i have to unsolder the flash memory and burn it with the old software on the programmer and solder it back? guys i really need help with this one so any help is really appreciated. thanks in advance.
File Description
< Caution >
Upgrade Procedure
ex)
File Description
Upgrade Procedure
ex)
Remarks
