SES12 - will be 95E
Motorized dish Gibertini 150 cm + LNB black ultra twin + actuator 24" + GBOX V3000... Motorized dish Gibertini 125 cm + LNB black ultra twin + actuator 18" + V-Box II.
11499,5 seems to be wrong... the correct frequency should be 11449,5.
Both telemetries can work in either LHCP or RHCP.
Dr.HD F16, TBS 6925, T-55, Laminas 120 cm
I think you're right, FCC made a typo.
In the document presented by Lockheed Martin to the FCC, is indicated 11449,5 (RHCP/LHCP).
S
s-band
Various L, S, C, X & Ka bits. 1.2m S/X/Ku/Ka Prodelin on Az-El
SE UK
Thanks @Marcus_21. The other beacon is active and visible if you look in the right place :-doh
SES-12 was about 3 times the distance compared to the previous capture hence the ~10dB drop in signal. The doppler shift was about -70kHz at the time of the plots and the settings were the same as for the previous post.
The orbit map also shows SES-14 approaching its final location.
I tried with lnb for circulars.... 11449,50 RHCP and 11703,50 LHCP.
Now it seems SES-12 has arrived near 113.5°E, this location was used already for in-orbit testing of SES-9, and was also visited previously by Astra 2A.
SES-12 has left in-orbit testlocation 113.7°E, and should be at final 95.0°E before the end of February.
6 satellite receivers,2 Meters,9 PC cards(tbs6983,6903,6590,6522,6209,2603,6909X,6903X,skystar hd2),2 tuners usb-tbs5927,Skystar HD.
I do not know what will be the coverage area of SES 12,but I hope the signal will be at least the half I get from NSS-6 now,Middle East beam.
Thanks @hvdh for the map.Looking at the beam in my area,I have the impression that what I want will fulfill.At 48 dBW the signal will drop almost to half? I hope I'm wrong :unsure
I
italy2006
Archived Member
starsat
iran
Somebody said they are now aligning both South and North Subscribers to ST-2 so Dish TV may not shift from NSS-6 to SES-12 but to ST-2.
