Setting up motor - cant get 30w :(
C
c.barber
Some Strange Dude :D
Likes
Starsat SR-X200CI and 80cm dish (0.3db LNB) on Hispasat 30w
Suffolk Coast
#1
Hi All,
I just set up my motor today its using USALS. I aligned to 1w (which I think is the sat closest to south as its one degree from south). I can get all the east sats fine, as well as the atlantic birds and telstar 12 satellites west of me. I cannot get a signal at all on 30w :(
I have tried aligning to 30w but then I can only get 15w and 30w. Can anyone help?
I did notice something when setting up my dish, I set the motor up how it said, (with my latitude set on the side) but the dish was pointing way too low, even when the dish elevation was set as high as it could go!
So I adjusted that until I could get 1w.
Why doesnt it work? I have set my latitude and longitude in the USALS setup :confused
Can anyone help - its greatly appreciated
C.Barber :)
C
c.barber
Likes
Suffolk Coast
#2
I cannot get 12.5w either
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#3
If your mounting pole is absolutely vertical then your motor elevation is out,
and you are adjusting your decliation on the dish in an attempt to compensate.
Have you been through the stickies in this section ??
L.:)
C
c.barber
Likes
Suffolk Coast
#4
my pole should be perfectly straight. I have been through some of the stickies. What do I need to do to fix this? As I say, when I aligned the motor elevation to my latitude, even with the dish elevation up as high as it goes, it still looked as if it was pointing too low down
Lancelot
Lancelot
Retired Mod
Likes
SS1.
South central
#5
Depends on your motor scale.
What have you got, and whats it showing ??
L.
C
c.barber
Likes
Suffolk Coast
#6
well heres a picture
I have the following scale on the motor:
J
Jeff_19341
Which motor have you got?
Some have both latitude and elevation on them .
If your latitude is 52+ (as you are near to me).
Your Elevation is 37+.
You beat me to it
C
c.barber
Likes
Suffolk Coast
#8
its set on latitude 46degrees
Its supposed to be on 52degree but then the dish points too low down
Hi Jumbuck in Felixstowe! I have a STAB-USALS HH90 motor - same as you except the model 90
It has a setting on the side for latitude but I dont see one for elevation, it says adjust the dish elevation in the book and it gives a value of 37degree for it on the map at the back of the book
Lancelot
Lancelot
Retired Mod
Likes
SS1.
South central
#9
Nice one JuMbuCk :D:D
Over to you in the studio then :-bighappy
Cheers mate :)
L.
J
Jeff_19341
I've just read the handbook do as it says set your motor elevation to 52 and a bit and your dish to 32ish.
I do hate those motors with the dish fixing stub hanging down, but that is just me.
C
c.barber
Likes
Suffolk Coast
#11
Ok then it looks as though the dish it pointing too low like that but hold on back in a sec
C
c.barber
Likes
Suffolk Coast
#12
no signal on 1w at all now and dish looks like its pointing at ground too much
J
Jeff_19341
OK let's go.
Having set up motorised dishes here and up in Hemsby I find the easiest way, as we are east of due south is as follows.
You have your dish and motor on the pole, I put a jubilee clip round the pole so that the motor can rest upon it. Nip up the motor bolts until you can just rotate it on the pole. Set your receiver to USALS, put in your latitude and longitude and drive to 1*W. Set the receiver to 11325H, 24500 (BBC World). Swing the motor with dish attached until you pick up a signal. Tweak the elevation of the dish and position on the pole for maximum signal/quality level. Tighten everthing up. That is it, all the other satellites that you are capable of seeing and receiving should then drop into the correct place.
C
c.barber
Likes
Suffolk Coast
#14
maybe i need to set the motor at 37degrees ?
C
c.barber
Likes
Suffolk Coast
#15
ok so it doesnt matter about the latitude on the motor, as long as I can get a signal on 1w it will work on the others?
C
c.barber
Likes
Suffolk Coast
#16
Ive just had a thought, I think my dish elevation thing is round the wrong way - its upside down to this:
h**p://www.usals.info/inglese/manuale_hh90/eng-hh90_05.jpg
look at step 7
J
Jeff_19341
Leave the motor set to 52+ latitude. I presume you have had your dish, in the past, on THor? if so just set it to that angle, slightly back from vertical or about 42 degrees then and try that.
Silly question, but have you got the dish mounting stub the correct way round? I've never used the model that you have.
C
c.barber
Likes
Suffolk Coast
#18
I have the small pole thing the right way round yes.
I cant get my dish high enough, with the motor at 52+ latitude, to get anything at all, it just wont go high enough. I am starting to tihnk that my dish elevation bracket is the wrong way round.
When I first got the dish, I got someone to set it up for me, as I couldnt get anything with it. He mentioned to me that the bracket was round the wrong way which is why I couldnt get anything. He also sayed "the other one is round the wrong way too but it will still work ok"
My Dish elevation wont go high enough with the motor set at 52+ latitude and the bit where the bolt slides along where the measurements are for the dish elevation are at the top, wheras in the manual the picture of the dish has it round the other way at the bottom
C
c.barber
Likes
Suffolk Coast
#20
this sounds silly but i think it is upside down lol :D
Hold on I will take a photo
