Setting up motor - cant get 30w :(
C
c.barber
Some Strange Dude :D
Starsat SR-X200CI and 80cm dish (0.3db LNB) on Hispasat 30w
Suffolk Coast
here is a photo
Where the bolt is on the elevation, it says 15 but its back to front i think
mhku
mhku
TM Nano ~ sg2100
Midlands
The cable connections are underneath i.e. facing the ground.
mhku
mhku
TM Nano ~ sg2100
Midlands
If mine is the correct way round then yours is upside down ;)
(the dish elevation "bit").
C
c.barber
Suffolk Coast
yes the cables are facing down.
I thought so lol it seems strange that the number 15 is back to front and the picture is the opposite in the motor manual.
Do you have a pic of yours so I know tomorrow how to put it together correctly?
Your dish bracket is upside down, swap it around, the pivot bolt is always at the top.
Now if you set your motor lattitude to 52 and follow the procedure as earlier posted, you should be able to find 1W and your arc will be correct.
NB: The lattitude setting on the motor body is not negotibale, it has to be set correctly, otherwise the arc will be incorrect.
PS. You don't have to link to photos, you can go into advanced posting and add them as an attachment in the manage attachments section, it is a pain to keep having to open new windows when trying to view a picture.
C
c.barber
Suffolk Coast
thankyou all for your help and thankyou for letting me know about the images rolfw :) I put them on my webspace, next time I will upload them how you said.
Once again thankyou all for your help, I will let you know how I get on tomorrow as its dark now
don'tknowdon'taskme
don'tknowdon'taskme
Part Timer
DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux
Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
that would be telling
been reading this thread can't wait to see how he got on till tomorrow same time same place here at satellites . co.uk
J
jimbo101
Dreambox 500s
ENGLAND
What I did when I set up my dish
Before I mounted the polar mount made shore I could get the pole level
And I could turn it without upsetting the level.
My Polar mount has the degrees set on it for dish i.e. were its pointing
I just used the default settings of the dish mount
I then set the polar mount up so the dish would be pointing at 1w
And mounted it all on pole and fitted in place so it was pointing south
I put the receiver on kiosk 1 and move the whole mount east west and lowered the polar mount up and down until I found kiosk 1
And locked the pole up
I then tried (without changing anything at dish end) hotbird and found it then 19e found it but couldn’t find 28e
I wet back out to dish and turned the pole 2deg too the east locked it up and tried 28 again it was there but not a strong signal.
So I went and lowered the mount setting two flats of the nut and locked it up
Went back and tried it again the signal had come up so I retried 19e 13e 1w they were all there and good signal but 28 was not as strong as it should be.
I then moved the whole pole 1 deg too the east locked it up once again .
This time 28e 19e 13e 1w were all fine and I tried 5w 8w 18w 30w they were all there
Now it may have been just luck I don’t know but it worked for me
Cheers Jim
C
c.barber
Suffolk Coast
had a look at the dish today and put the elevation bracket the right way round! It works fine now!
There seems to be just one problem i cannot get 12.5w for some reason but all others are fine
Topper
Topper
Amo Amas Amant Admin
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
Well done got there in the end
I wouldn't worry too much about it what on here will you miss
J
Jeff_19341
Hi c.barber
Try 11428H, 30000 on 12.5*W, Opensky Promo. Strength of 80+ and quality of 90+ just down the road from you.
BTW what angle did the dish finish up as, just for interest's sake.
Cheers
C
c.barber
Suffolk Coast
I cant seem to get nilesat or 26e either - should I be able to?
The angle on motor was 52 and dish elevation same as what you posted
C
c.barber
Suffolk Coast
quality on that channel is 80% so I can get it!
don'tknowdon'taskme
don'tknowdon'taskme
Part Timer
glad to hear you got it done
J
Jeff_19341
Hi c.barber.
Nilesat on 80cm dish is marginal.
Arabsat you should get bet not 80%, you are getting bleed over from the cluster at 28*E. If you have cold mist in your locality both the above will drop out.
C
c.barber
Suffolk Coast
ok thanks for your help - yes it is very foggy this morning isnt it!
I enjoyed watching the American Football on 15w last night
