Setting up motor
Sab
Likes
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
#1
I've got a 90 cm dish with a DiSEqC 1.2 motorized H-H mount.
The elevation level has been checked and is correct. My problem is I get a good signal on 19', 13', 7'. 5'east and 1'west. I can't pick up 16' east for some reason or the remaining west satellites.
I have been able to get 30' west previously but couldn't get the east satellites. Which bit needs adjusting please.
Likes
1,279
#2
Can you also get 28.2 East Sab?
Can't really explain why you can't get anything on 16 East, are you sure that you have set a transponder with something on it?
waverider
Salty Tech Monster Mod
Likes
Protek 9750 HD IP, Spiderbox 9000HD. Cryptik Digital H-H Mount with1.2m Oval Dish and a box in the garage consisting of 2 obsolete STBs, various Cards and a couple of cams!
South East England
#3
What settings in the setup menu on your STB have you selected? if its DISEqC that could be your problem.....I found that selecting motor is the best way as you are able to pulse the motor to receive the best signal then save it's position! OR maybe when you initially tightened the nut's of the motor mount if you did'nt tighten them evenly (crossways) the bracket can distort, this then can affect the arc of the dish from east to west.
Likes
Edinburgh / Scotland
#4
Yes, I do have the same problem...
I have a 1m motorised system, and from Scotland I can only get 1W, 5E, 13E, 19E, 28.2 E... but not the 16E which are right in the middle of the excursion range... its worth mentioning that 5E comes with just about 40% quality and about 50 / 60% signal strength... not sure if the dish need fine adjustment...
Cheers,
waverider
Likes
South East England
#5
Cheers,
If you are receiving 13'E & 19'E.. then it is most likely to be the set-up in your STB m8!....so if you have the option change it from DISEqC to Motor then manually pulse the position of the motor with your remote to receive the strongest signal..save the position, scan satellite then exit setup menu.
Sab
Likes
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
#6
This could be where the problem is.
I've noticed that I'm picking up 28'E on 19'E 80+ strength (receiver) now! However, after fine-tuning dish etc. I can pick up 30' w with a 50-60 strength but 1'W has almost vanished.
Razor
Likes
Ireland
#7
I recently had the pleasure of watching Channel Hopper set a motorised system up. First he made sure he had a good fix on 1W, next 28E and then 30W. After that all the birds in between must be there, he just pulsed the motor over to a bird ( say 16E ) by hand, moved it back and forward while watching the signal meter and when best strength found. He saved that and moved on to the next bird, and so on.
If there is a button on your remote to jump the motor by hand you could try this.
Likes
5,389
UK South
#8
Close but no cigar
If it was that easy Id be out of a job
If the arc is not correct (East and West in line, either above or below the true line ) then you dont have a chance. Critical to get the majority of satellites on either side of South correct in the first place, usually by only adjusting the dish on the pole.
Everything then is done in very small increments, constantly checking that any modification to one point of the arc doesnt bugger up a larger part of the rest. This is the declination and elevation bolts, sometimes one at a time, sometimes both.
Then when there is no improvement, go back to East / West adjustment
Manke sure nothing is tightened fully while doing the above, as a dent in the post or a lock washer can spell disaster for fine tuning.
Then nip up all bolts in equal amounts , taking the readings as you tighten them
waverider
Likes
South East England
#9
Yep I'll agree to that hopper..bit like torqing down a cylinder head! :D
waverider
Likes
South East England
#11
Razor said:
Now that I can do....and have done many times.
Why....you on the spanners too razor?
Likes
5,389
UK South
#12
Funny enough Im just doing that on the 1100F, not one of Hondas best, but then it is a 25 year old design. A phenomenally heavy lump and indifferent handling, Im not sure how people got them round the TT in one piece
Sab
Likes
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
#13
Thanks to all for advice.
I did start with a strong signal of 1'W and found East satellites (except 16'E). 30'W was weak at his stage. Is 16'E lower or higher than the other East ones?
I then adusted dish elevation and got a strong signal of 30'W but a weak one on 1'W.
This was when I picked up 28'E on the 19'E slot.
I agree with Channel Hopper and Razor but my main difficulty of the last week or so has been the strong wind and damn rain!
It's annoying when you are 95% there and one slight adjustment in the wrong direction throws a spanner in the works. On the bight side, I'm a novice so I'm pleased with the progress so far!
If you don't succeed at first, try again! When I finally do succeed I should be able to thread a needle at 100 metres!
Razor
Likes
Ireland
#14
Well Sab your doing better than I did, I had to get CH to put mine up.
Likes
1,279
#15
I reckon the problem is your lattitude setting on the motor body, when you goto 1W, does tilting the dish downwards or upwards improve the signal?
Sab
Likes
DM 500s
Gemini
Release 0470
CCcam 214
North Wales
#16
Yes rolfw it did and also on the other sats. as well.
The pole is plumb as you mentioned in an earlier post and the lat. is 53.3 where I am.
I've just checked the lat. on the motor and its on 53. Weight of dish and my heavy hands. I'll give it another go next week. Dont't want to miss the footy on 30'W.
PS One of the problems I'm getting is that the distance between lat. 54 and 53 on the motor scale is only about 1 cm.
Likes
1,279
#17
A relatively small adjustment will make a bit of difference, so it will be a case of suck it and see, you may have to try a few settings to work it out.
