dhracer1000
- Jun 21, 2007
- Age
- 44
- York
I've just been trying to set up a Technomate tm-1500 ci+ receiver with an existing sky digital 43cm dish and i think Cambridge single LNB. In set up mode on 28.2E i'm getting the following readings
Level 21-25% and Quality fluctuating between 3 and 8%.
I've checked the cable at the receiver end and the cable seems fine.
The dish was already installed when i moved into the house so i'm unsure if there are any problems with.
Has anyone got any ideas on what i should try first?
Would cleaning the LNB make any difference?
