idavies
- Jan 4, 2009
- Age
- 55
Sky HD
Vision 5/12 Switch
Quattro LNB
- UK
I have a Quattro LNB on an 80cm dish connecting to a 5/12 switch, and then a Sky HD box.
The symptoms I have is that on one of my connections to the HD box provides 75% signal quality but 0% signal strength. The other connection shows 100% signal strength and signal quality. The problem follows the connections, i.e. if I swap connections, the problem follows the cable.
What might give rise to these symptoms?
