signal quality
bri-sat
force 1144 receiver, 80cm dish, 0.3 lnb, cryptic motor.
Manchester
I got to use 2 different receivers (force 1144s & technomate 7755) with the same dish/motor set-up over the last week but have been getting different signal quality & strength readings.
For instance, art sports on the force receiver is getting a 58-61% strength reading while on the technomate its 70%, tps football on the force is 67-70% on the technomate its 80%.. etc etc
Does this automatically mean the technomate is a better receiver or do different receiver manufacturers have differing ways of measuring signal strength?? I would have thought going on price the force receivers would be of better quality!
Receivers will only give a comparative figure, they are not accurately calibrated and often give a percentage so cannot be used as a reference. A better test is to find a weak transponder and try it on both receivers, then try it with a wet tea towel draped over half of the dish and see which one still receives the channel.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
I think rolfw ought to get a certificate which makes him the national tea towel salesman of the year, O-Ha O-Ha certainly must keep production going... what other uses do they have?:p
LOL, don't think that tea towels have had a fair crack of the whip since I progressed to the spectrum analyser, so why not a little positive discrimination now. :D
Yeshi
Norden - Near Edenfield (not Rochdale)
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
I use a damp jiffy clothes as a rule.. the blue one with the white dots on :)
steffo78
28E 19E on 120cm Gibertini homemade sidemount with Gibertini feedhorn, Inverto C120. 5E 1W on 85cm triax. Digiality VC-CI 204 and Triax dvb-65s receivers. Matrix-cam not working. Swedish Canaldigital "local", Norwegian Viasat.
Sweden/Norway,Telemark
My receiver, A Triax dvb-65s needs only 3.4dB on Astra 2D to get stable picture without freezing.
After thinking about it I see that it must be wrong.
This receiver takes away about 1-2dB on the meter.
Your Force receiver should get you a better picture to watch but I dont know about sensitivity.
don'tknowdon'taskme
Part Timer
DreamBox 800HD DreamBox 7025 PVR160g HD,500s Dreambox ,Sly+ Full Package,SkyCard 2, And a Eagle 500 Clone DM500 TM755,TM9100 Linux
Channel Master 1.2m,1224EL Supermount Orbit Tracking Motor With c120 Feed Horn Invacom Quad Lnb Cas3 SC Dragon Progr
that would be telling
were did u get them teatowels from looking for a xmas present for my gran she would love them.
Topper
Local company East Lancs towel Company Nelson
and yes you can buy online click here
