Signal reports after 2B withdrawn from 28ºE
Signal reports only in this thread please. For conformity please only post reports for the following frequencies.
Vu+ Ultimo + Fibo 90 (unless stated).
10906V ITV3 (1N spot), SNR 64%, 10.2dB;
10964H Channel5 (2F spot), SNR 48%, 7.8dB;
11778V EPG background audio (2A North), no lock (on 1.8m dish, SNR 39%, 6.4d:cool:;
12051V S4C (2A South), SNR 84%, 13.7dB;
12110H Cartoonito (???), SNR 68%, 11.0dB;
12207V Sky News SD (???), SNR 65%, 10.4dB;
12480V 4Music (2A North), SNR 30%, 4.8dB (unwatchable);
Zorba
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
Limassol, Cyprus.
3m prime focus dish.
11778V -working fine
12051V -working fine
12110H -working fine
12207V -no signal
12480V -working fine
Galashiels Scotland
All frequencies working fine with excellent signals :D
cazhh
Elmshorn, Schleswig-Holstein
Location: _maps.google.com/maps?q=53.752822,9.663591&ll=53.736833,9.722557&spn=0.122047,0.32341&num=1&t=h&z=13
Setup: 100cm Gibertini, IBU quad, TBS5922 & EBSpro
Bad weather (all SNR down due to rain)
10906V SNR15.2 RF -69dbm
10964H no lock -82
11778V 14.9 -62
12051V 12.8 -70
12110H 13.9 -68
12207V 12.3 -73
12480V 14.9 -70
And nothing is better than a graph:
  • 28.5E-RFScan-hv-300113-0000.pdf
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
10906V - 98%
10964H - 80%
11778V - 100%
12051V - 50%
12110H - 70%
12207V - 56%
12480V - 100%
My readings with a 45cm Multytenne dish in damp conditions outside. Ede, The Netherlands.
oldfart
laminas 2.7 offset
Invacom Quattro LNB
Chayofa, Tenerife
DM8K
Tenerife
10906V DVB-S QPSK 22000 5/6 ITV3; snr 66%, 10.5dB
10921H DVB-S2 QPSK 23000 8/9 Alibi HD (1N); snr 61%, 9.85dB
10964H DVB-S QPSK 22000 5/6 Channel5; snr 42%, 6.8dB
11778V DVB-S QPSK 27500 2/3 EPG background audio; snr 40%, 6.48 dB
12051V DVB-S QPSK 27500 2/3 S4C; snr 88%, 14dB
12110H DVB-S QPSK 27500 2/3 Cartoonito (F1 SD); snr 24%, 4dB
12207V DVB-S QPSK 27500 2/3 Sky News SD (???); snr 22%, 3.5dB
12480V DVB-S QPSK 27500 2/3 4Music; snr 44%, 7dB - no lock
all locked(unless otherwises stated)
Under 5dB - breaks up
clear sky
jaru
Gibertini OP 100 X, IBU, TeVii with VDR
Munich
SNR calculated from driver's raw value to dB with formula from driver source code,
Munich, 1m dish, IBU LNB, overcast/drizzle
10906V 11 dB (max for the setup)
10964H ------ no lock
11778V 11 dB (max)
12051V 9.9 dB
12110H 9.3 dB (no video, might be false reading)
12207V 6.5 dB
12480V ------ unable to tune
I don't have a sky subscription, 12110 and 12480 seem to carry encrypted channels only.
Istanbul, Turkey
This migrate is dissepointing for Turkey. Almost all the signals down in here.
I can only get signals below tp after migrate with 170 cm dish in Istanbul
On the www.apps.ses.com/ for Astra 2F European Beam it seems there are footprints on Istanbul And Canarian Ireland and it seems it is not exist. is there any possibilty if astra increase the signal levels for the places?
11720 H - %30-35 OK
11739 V - %20-30 OK.
11798 H - %25-30 Lock bat somethines freezing
11817 V - %28-29 Only in the morning and evening OK
11876 H - %40 OK .
11895 V - %26-32 OK
11973 V - %28-29 Only in the morning and evening OK
12032 H - %20-25 In morning and evening freezing not ok
12110 H - %26-28 Only in the morning and evening OK
12188 H - Only In morning and evening get signal but not ok
12226 H -Only In morning and evening get signal but not ok
12266 H - Only In morning and evening get signal but not ok
12304 H - Only In morning and evening get signal but not ok
12324 V - Only in the morning and evening Ok..
12363 V -Only In morning and evening get signal but not ok
12460 H - Only in the morning and evening OK.
12480 V - Only in the morning and evening OK
miha20
Kiev, Ukraine
Kiev,Ukraine, 1.1m Triax dish with Inverto BU
10906V no lock
10964H no lock
11778V 9db
12051V 6db
12110H no lock
12207V no lock
12480V 9.6db
Guys can we please stick to the transponders mentioned in the original post otherwise the data is going to become unmanageable. If we all post about the same transponders it will be much easier to do comparisons.
Retired moderator
Vu+ Duo 4K SE
Dr.HD F15
My setups in Helsinki, Finland:
1.8m dish, Invacom QDF-031 Quad LNB 0.3dB, Dr HD F15 receiver quality readings, overcast
10906V ITV3 (1N spot), no lock, flickering around 0.5dB
10964H Channel5 (2F spot), no lock, flickering around 0.2dB
11778V EPG background audio (2A North), good signal, 16.8dB
12051V S4C (2A South), good signal, 12.2dB
12110H Cartoonito (???), no lock, flickering around 2dB
12207V Sky News SD (???), no lock, 0.0dB
12480V 4Music (2A North), good signal, 18.5dB
80cm dish, Inverto Black Ultra Twin LNB offset by 9 degrees, Dr HD F15 receiver quality readings, overcast
10906V ITV3 (1N spot), no lock, 0.0dB
10964H Channel5 (2F spot), no lock, 0.0dB
11778V EPG background audio (2A North), good signal, 13.5dB
12051V S4C (2A South), only watchable in the evenings, 3.6dB
12110H Cartoonito (???), no lock, 0.0dB
12480V 4Music (2A North), good signal, 15.4dB
1.05m dish, 0.4db single LNB, Humax HD Freesat Box
Kamnik Slovenia
Hi
Location Kamnik Slovenia (12Km North of Ljubljana)
1.05m dish Cheap 0.2 LNB
10906V Strength 85% Quality 80%
10964H Strength 0% Quality 0% NO SIGNAL
11778V Strength 100% Quality 100%
12051V Strength 100% Quality 100%
12110H Strength 100% Quality 100%
12207V Strength 100% Quality 90%
12480V Strength 100% Quality 100%
Good luck
denis1501
Lazio, Italy
1.25m offset dish for Astra 2 28deg. using Inverto Black Ultra 0.3 quad lnb, Amstrad Sky+ HD, 80cm dish for Hotbird, Sky Italia, Tivùsat, Lenovo Ideapad Z570, 10 mbits broadband.
Sunny Italy
Lazio, Central Italy, 11.22am 30/01/2013: 1.25m offset dish with Black Ultra lnb:
10906V ITV3 (1N spot), SNR 47%, 7.6dB;
10964H Channel5 (2F spot), no signal
11778V EPG background audio (2A North), SNR 34%, 5.6d:cool:;
12051V S4C (2A South), SNR 79%, 12.7dB;
12110H Cartoonito (???), SNR 80%, 12.9dB;
12207V Sky News SD (???), SNR 73%, 11.8dB;
12480V 4Music (2A North), SNR 54%, 8.7dB
sonnetpete
wordpress.com
Normandy, France
Heusse, Lower Normandy, France. Triax TD88 with Technomate LNB (as part of a multi sat setup but at centre) feeding a Vu+ Solo.
10906V SNR 99% AGC 80%
10964H SNR 99% AGC 76%
11778V SNR 90% AGC 76%
12051V SNR 80% AGC 71%
12110H SNR 90% AGC 71%
12207V SNR 79% AGC 73%
12480V SNR 91% AGC 76%
strs65
Decoders: VU+ Uno, DR.HD F15
DVB cards: TBS6983, TBS 6925
Dish 1: Tecatel 1.10m
LNB1: Smart Oxid
Motor: Amiko DM3800
LNB2: Invacom QDF-031
Greece (Crete - Chania)
At 10:30 AM (local time), with the TBS6925
10906V, 0
10964H, 0
11778V, 0
12051V, 9.5 dB
12110H, 5.3 dB
12207V, 4.2 dB
12480V, 0
6:30 PM
10906V, 0
10964H, 0
11778V, 0
12051V, 8.4 dB
12110H, 4.5 dB
12207V, 3.7 dB
12480V, 0
0 = no lock, not signal at all or very close to noise in the spectrum
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Latvia, near Riga, 1,5m PFA, light snow/rain (just used basket of hot water to remove snow from dish) :-toilet , DM8000
10906V ITV3 (1N spot), nothing
10964H Channel5 (2F spot), nothing
11778V EPG background audio (2A North), 84% 13,48 dB
12051V S4C (2A South), 67% 10,77 dB
12110H Cartoonito (???), 43% 6,99 dB
12207V Sky News SD (???), 25% 4,12 dB breaking
12480V 4Music (2A North), 82% 13,32 dB
Istanbul, Turkey
At 7 pm in local time in Istanbul with 170 cm dish and smart titanium lnb
10906V, 0
10964H, 0
11778V, 0
12051V, 0
12110H, 0
12207V 0 Only in the morning very low signal, just lock but not wachable.
12480V, 0 Only morning and evening watchable. 4.10 db
Br492
1,25x1,40 movable alu dish now pointing Astra 2 off center Astra 3
75cm center Astra 1 off center HotBird.
More to come
Preveza West Greece
First post here from me.
My reception west-north western Greece ,preveza:
10906 nothing
10964 nothing
11778 13,5 dB
12051 12 dB
12110 14,5 dB
12207 13 dB
12480 12,5dB
19:40 local time weather clear
Schroeder
2.2m Pasat prime focus with Invacom c120 quad LNB, PACE DS430N, Ferguson Ariva 200, Humax Foxsat HDR
Albatera, Alicante, Spain
Nearest town: Albatera, Spain
Ferguson Ariva 200HD
Pasat 2.2m prime focus dish
Invacom quad c120 lnb
Cable length approx 35m
10906V, Sig: 87% Qual 76%
10964H, Sig: 88% Qual 75%
11778V, Sig: 0% Qual 0% (18:30 CET); Sig: 86% Qual 40% (10:30 CET - nothing picked up)
12051V, Sig: 84% Qual 75%
12110H, Sig: 86% Qual 76%
12207V, Sig: 86% Qual 75%
12480V, Sig: 89% Qual 72%
With exception of 11778v all above channels are received 24/7.
Unconvinced 12480v is on 2A North due to the above signal strength which is closer to 2F spot
In general 2A north beam channels are not received on the Ariva, although I can receive them on the Sky Pace DS430N except during the afternoon/early evening
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
Estonia-Tallinn:
C-Tech 5100C,LNB Black Ultra,Toroidal T90.
10906V ITV3 (1N spot), 0
10964H Channel5 (2F spot),0
11778V-80% Quality
12051V-56%
12111H-0
12207V-0
12480V-80%
Estonia-Viljandi:
DM 800, 1,8 m Prime,LNB Inverto Black Pro
11778V-93% Quality
12051V-61%
12111H-0
12207V-0
12480V-81%
