SIGNAL STRENGTH vs QUALITY
S
Stuart
Just entered into the world of satellites - briefly with 80cm dish - 2 LNB's - Astra (19deg E) + Hotbirds (13deg E). Primariliy interested in the Italian content, but I seem to have a problem with "RAI3" - sometimes there, sometimes not.
Receiver telling me that Signal Strength is GOOD but Signal Quality is LOW.
Is this a known problem with this channel? ("Rete4" is also a bit marginal)
Any ideas or suggestions would be greatly appreciated - thanks
They should be fine Stuart, perhaps you need to tweak the Dish or adjust the Skew on the LNB slightly. Have you got two separate LNBs or a monobloc?
S
Stuart
Rolf - thanks for that. I have 2 separate (0.3db) LNB's which were only installed yesterday. If the problem persists I'll get the install guys back to check it out - Cheers.
As a matter of interest, which LNB has the prime focus?
S
Stuart
Sorry - don't know the answer to that.
I know that I originally wanted Hotbird + Eutelsat W2, but apparently the LNB's couldn't cope with the 3deg difference as they were touching each other.
Good way of telling is looking at the dish from behind the LNB, if the right hand one is mounted directly onto the Boom and the other is offset, then Hotbird is the prime focus which is correct.
S
Stuart
Rolf - can't get to the installation til later on, I'll have a look then.
Being 'techie' - but not about sats yet - curious to know why one should be prime over the other. Is it anything to do with the signal strengths?
Yes, exactly that. :)
S
Stuart
Rolf - Hotbird is prime focus.
Problem seemed to be the skew as you suspected. Gave it a tweek and it boosted the signal quality -solved the problem - thanks for your help. Just one other question before we close the thread, and excuse my ignorance, but what is a PID? Regards
A PID is an ID number for audio and video, sometimes you may need to enter these to receive a hard to receive channel, or a specific language in audio.
