Silvercrest SL65 combined with motor
Likes
silvercrest sl65, motor
belgium
#1
Hi all
I have a Silvercrest SL65 receiver, hooked up to a motor since a few days
I'm using USALS to go to the different satellites
Now I want to add a satellite that is NOT in the pre-programmed list.
How do I go about? There is nowhere in the menu a possibility to enter the satellites coordinates (neither E or W)
So how should I do this? Or am I limited to the pre-progged sats using USALS and do I need to switch to Disecq 1.2?
Also, there is NOTHING in the manual about this...
Thanks for your help
Robbo
Likes
5
Gravesend,Kent,UK
#2
I haven't got one,
but according to the manual its
MENU>Installation>Add satellite
OK
V+
small menu appears with sat names,
select 'User satellite'
Press '1' to enter a name for it
etc etc.
Page 36 for comag SL65 manual. _http://www.manualdirectory.co.uk/Detailed/6950.html
Likes
belgium
#3
Yes,
This is to add a new satellite, that's working OK
The thing however is that I want to add a satellite, so that I can control it using my motor. The satellites that are preprogrammed (Astra1, Hotbird, Turksat, ...) work OK, but I would now like to add astra 3A on 23.5E which is not in the list yet
And I do not see any possibility at all to change the coordinates for the satelite in my menu (the coordinates of my location are there)
