Sirius
N
nordy250
Hi I live in surrey, (uk) and have a 1.6m dish with 0.2 lnb, i an get all chanells on viasat during the day but at night (around 8pm) all the vertical channels loose all signal and come back at about 7 in the morning, is there anything i can do to not loose signal, the dish is alligned properly,
any help appreciated!
Skybox F3
Get a bigger dish!
N
nordy250
Analoguesat said:
Get a bigger dish!
yeah well i cant really, just wondering why the reception dies during the night?
Skybox F3
Various possible reasons:
Change in atmospheric conditions
Also, the satellites do move around a bit over 24 hours, and your dish is obviously marginal for your location. A tiny decrease in received power may well be enough to tip your reception over the edge.
C
c.barber
Some Strange Dude :D
Starsat SR-X200CI and 80cm dish (0.3db LNB) on Hispasat 30w
Suffolk Coast
thats strange......... :confused
I have an 80cm dish and 0.3db LNB and I can get all channels on sirius 24 hours a day :confused
I had my dish at sirius last week
Skybox F3
You are closer to Scandanavia than the op - signals from 5E drop off rapidly from Suffolk / Norfolk. Your area gets the strongest signals in England.
FWIW i can just get Sirius 3 during fine weather on my 1m dish. Any rain and its goes away.
C
c.barber
Suffolk Coast
sorry I forgot about where the scandanavia beam is. I assumed that the further south, the better signals :D that is true but not for this sat
Apologies
UK South
a 1.6m (if it is a solid) should still get all the channels at night. I think the system needs a bit of professional tweaking
N
nordy250
yes what do you mean by proffesional? yes it is solid, but I have to use the viasat box which may not be a sensitive as i need?
BadWithComputer
BadWithComputer
The Local Drunkard
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
I´m still amazed i get some sirius transponders in the south of spain with an 80cm offset. Surely in scandinavia it would be easy??
Skybox F3
There are at least 5 different footprint patterns in use at 5E, (just on the sirius birds) with I think 2 being pan European beams. There are also 3 spot beams from the Intelsat 10-02 craft colocated there, so it all get horribly complicated.
S
sat200
technomate
uk
that is correct there are 5 beams or sirius the european beams only need a 45cm dish as for the scandanavian beam where there viasat channels are E.G tv1000 you need 1.2 to 1.8 metre dish i can get them with 60% signal on my 1.2 metre channel master with 0.7 cambrige lnb but on my 1.8 metre channel master i get 98% signal on them, btw channel master are proble the best dishes in the world,
btw im new here, also is this analougesat from digital spy
Lancelot
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
