SKY HD + sound problem
R
ropper1975
sky hd
durham
ive a sky hd box made by samsung model 0.7.070.input 1 signal strength is 100% as is input 2.signal quality is one block less on input 1 and 2 less on input 2.
my problem is especially more noticeable on hd channels is i keep loosing sound for split seconds at a time.what can be causing it as its getting really annoying now
have a new dish and lnb fitted as well this happens no matter what the weather is like
i am watching it through pioneer 42" hd plasma any help would be appriciated
satelliteman
satelliteman
East Midlands, UK & Lanzarote, Canary Islands
Hi, what channels are you experiencing problems with?
There have been some reports via stockists that a forced software update can sometimes correct sound glitches as a software issue but may not be related in this case of course.
R
ropper1975
sky hd
durham
all the hd movies currently watching the ark knight and lost count of times ive lost sound
im sure my sports chanels are affected as well
O
Oakey22
Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11.
Staffordshire
i have a problem with mine every now and again, lose sound for a split second every now and again
R
ropper1975
sky hd
durham
Looks like a common problem a few lads i work with having the same problem as well not just with hd channels
bit shit paying £10 extra a month when it doesnt work correctly
which from what one lad was telling me and it came from sky installer the £10 is getting scrapped soon
Tout Rond Bon Oeuf
That rumour has been doing the rounds for ages and ages - But it may eventually happen, I suppose.
harbottle
harbottle
Swansea
Got the same sound problem with our Amstrad HD box. Its only when you watch it via the HDMI though on the telly, it doesn't happen when you watch it through AV1 (SCART). Its every channel not just the HD ones.
I thought it may be a TV issue but the PS3 is fine
