Sky Remote Control Codes for Tevion
misterminibus
Lancashire
Kodi
Lancashire
Help
I have just bought a Tevion 27" widescreen LCD tv from Aldi but there is only one code (696) available on interactive for Tevion and my model (GTV 2702) isn't listed .
I have tried this code but it wont work ie my sky control works the sky box but doesn't work the tv for controls like volume etc.
Has anyone got a code for this unit or perhaps any idea where I can obtain one?
You may be better looking for alternative versions of your TV, it is unlikely that Tevion is the only version of that set, there may be a code for a different manufacturer which works.
Unfortunately there are probably many of the newer flat panel TVs for which there are no codes yet.
misterminibus
Lancashire
Kodi
Lancashire
phillbutt180 said:
Try _http://www.urcsupport.com/
thanx for the link phil but my control isn't on there its a standard sky control and it works fine with the sky its just the tv it doesn't work with.
misterminibus
Lancashire
Kodi
Lancashire
Its a good idea, I would like to think that it was just "badge engineering" but before I bought the tv a spent many hours looking around the likes of dixons and currys for a better buy or even the same set but did not see the same one.
gaorchard
Sky HD
Southport
The code for this tv is 1326
Let's hope his TV actually lasted four years, then! :-rofl2
(Welcome to the Forum ! :))
4dbennett
lifes not a practice run
SPIDERBOX 9000HD, 1.2 and Humax Foxsat HD,Hitachi L500HDD
Acer Aspire 5315 Lappy
torfaen south wales
try 0065 this is a common code that has worked on lots of tv,s for me
regards Dave
How old is the Digibox remote?
If you take the battery cover off and look inside for a sticky label. If it's earlier than Rev 6 then it won't accept the 4 digit codes and therefor is excluded from all the most recent TVs.
This is not a guarantee that you'll definitely find one though!
