I am trying to use, the software which came with the card itself.
The motor works fine, because when I move it manually it moves. The skystar 1 is not like the sky star 2, in that you have to play with a diseq plugin, the skystar 1 supposts diseq from whitin it.
The settings I am using are these,
Under the Tab LNB Switch
LNB SETUP 1 (only)
LNB Power: ON
LNB Type: Universal
22Khz: Disable
ToneBurst: Disable
Databurst: Disable
Diseqc: Disable
Under the Tab Dish Setup
Select Dish: Dish 1
Dish Type: Usals
Longitude and Latitude : Those corresponding to my country
LNB Setup: Setup 1
I have a 1meter dish with a motor and one lnb of 0.3db.
I have tried other software but still to no avail. I even changed cards, because I thought the first one was faulty
I have tried all settings, but I think I am surely doing something incorrect. I opened this thread because I know that here there are some peeps who have a skystar 1, who might give me a helping hand.
