Skystar2 pci and nforce4 chipset- Warning!
Likes
Skystar2,
Fortecstar Passion HD,
moteck 2100, Lidl 80cm dish
Having discovered that I can't use my Skystar2 pci in my new motherboard (Asus A8N SLi), I thought it worthwhile starting a new thread to highlight the issue, which has resulted in some people damaging their motherboards.
See this link:-
_http://www.dvbviewer.com/forum/index.php?showtopic=7761&st=0&p=63636&
I would also like some advice on what to do now, as I need a Skystar2 compatible Socket 939 motherboard, which will accept my AMD64 4000 cpu and my nvidia 7800gt pci/e graphics card.
Any suggestions as to what would be best?
Woody
kamaleon
Likes
skystar2 pci skystar usb + porty lidl camping dish maybe one day i'll have a dreambox 500s...
str8 frum da wesside innit?
#2
yes, it's something to do with a lack of voltage on the pci bus on that mobo
i have a msi neo4 platinum nforce4 ultra running sweet with ss2
you might also want to check out the new geforce 6150 onboard gpu µatx mobos
pinkerton
Likes
I'm on my second Asus A8N MB which has now gone belly up, and I have read various reports of it not likeing TV cards in general. I have ordered a Skystar USB and probably have to RMA the second motherboard.
These things should come with a warning!
kamaleon
Likes
#4
i'm very very glad i didn't get one of those mobos...
i think there's a thread in dvbnetwork, otherwise should google for it. maybe abit, epox, dfi, gigabyte, msi all work fine with pci device like the ss2...
Likes
35cm portable dish and Comag Porty II FTA Reciever (Lidl kit), Nokia 9850T DTT box.
Athlon 2600+, 512Mb RAM PC with Nebula DTT Card
South Wales, UK
#5
Oh dear, that doesn't sound good for me. Not good at all :(
pinkerton
Likes
Well I have RMA'd the Asus and am now the owner of a DFI lan Party Extreme. Someone stated on another forum that he was running the skystar2 on a DFI Nforce motherboard, only thing is I'm terrified to try it! I dont want to see a third board die on me, I think my retailer must think I buy them and throw them at the wall.
Likes
Skystar2,
Best of luck Pinkerton.
If you do decide to take the plunge, let us know if it works.
I just bought a Twinhan Starbox USB2 to use with my ASUS board.
Can't get the bl**dy thing to work though :(
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#8
I read somewhere yersterday that a very high percentage of the Starboxes have been returned as faulty. Try a Google search.
Likes
Skystar2,
Got the Twinhan box working now, it came with a duff USB cable!
Seems to work fine with My theatre and plug-ins.
HDTV looks good on it as well :)
Couldn't get it work with Progdvb though, prog freezes when scanning for channels
Not yet worked out how to move the moteck from MT without USALS, is this possible?
pinkerton
Likes
OK, I went for it and I'm glad I did!
Skystar2 PCI working fine on a DFI Lan party Nforce4 Extreme. Even rebooted a couple of times and all seems well (touch wood). So all I can say is never use a Asus Nforce4 with a skystar2.
Skystar USB going on ebay tommorrow as surplus to requirements.
Likes
Skystar2,
Pleased to hear it works.
Just for the record could you give the model number of your DFI board, if my Twinhan box goes belly up I might need to get one.
Also, are you using your SS2 to drive a motor?
pinkerton
Likes
I bought this board: _http://www.dfi.com.tw/Product/xx_product_spec_details_r_us.jsp?PRODUCT_ID=3872&CATEGORY_TYPE=LP&SITE=US
I have a motor but not set it up yet, so watch this space :)
D4ftpunk
Likes
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
StrongSat FTA Reciever
80cm Dish + 45cm Dish via Disecq A/B.
England
#13
Im using a gigabyte K8NXP-9 motherboard which is nforce4 and my skystar2 works perfectly, the K8NXP-9 has a DPS card in it. which makes power nice :) simply heh.
Try it
