SkyStar2
SeanCorky
Technomate 1500CI+
ISS 1M Offset Dish
Moteck SG2100A Motor
Merseyside
Hello everyone
I bought a SkyStar2 PCI a few weeks ago and then found out it didnt work on my motherboard (Asus A8N-E, doesnt work with nForce4 boards)
Anyone know a workaround, except for, obviously, buying a new motherboard ?
Cheers
remlap
Wales
Might be a better option posting this in the "PC Card Systems & Internet by Satellite" section for more help than in here.
pinkerton
I blew 2 Asus boards with a skystar2, I now have a DFI LAN NF4 Expert motherboard and it works a treat. Your only other option is to buy a USB reciever, but make sure its USB2 to recieve HD.
DSM
Technomate 1500CI super, 78cm solid dish, 0.2db LNB, HP Pentium4 PC with XP Home. Foretec Star Lifetime Diamond (more trouble than it's worth)
Merseyside
Is it just Asus motherboards that the skystar blows? What motherboards are acceptable?:(
pinkerton
Not sure, can only speak from my experience. Certainly dont use a skystar2 with a Asus A8N-SLi Premium nForce4 SLi or you will blow it. I now have a DFI LAN party NF4 Epert and that works fine with it.
remorema
mosc wanted
U4102 ; octal (waiting for mosc)
Margem Sul
its working pretty good on my 50€ Asrock 775Twins HDTV. :)
Prophessor
Folding*home
koizo.sourceforge.net
[ Relook 250S ]
Madeira
Thi sort of problems should be clearly pointed out on technistars site, they should at leat have a clue as to what works and what doesn't. Instead they just say nforce4 is a no no and for all other chipsets to get the latest chipset driver.
Also their support line, or should I say email support is useless. It's a shame. O-no
