slowing down a motor with a vbox
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
hi to all can anyone recommend a way to slow down my motor which i use with a vbox as mine seems to move veryfast,and i hope it might also reduce the noise slightly thanks iwol
Snuffer
Skystarcard,Fortec's life time ultra's, MaxPlus 2100's,Dreambox and a Tandberg
Amsterdam
Change the gearbox or use a big Resitor to convert the Voltage down to lowerpoint where it still works.
I prefer the first option.
p.s. what for motor is't??
Some info here on vbox mods -
http://www.satellites.co.uk/satellite/dish-setup-single-sat-multi-sat-motorised-systems/48137-inside-picture-v-box-ii.html
iwol
satlook micro
yorkshire
cheers guys will have a look its a superjack arm
Manikm909
Small'ish Dish Man
Kent, UK
its funny i was going to ask this question but searched first which led me here
my Jaegar SMR128G - moves very fast and it sometimes overshoots positions only a little but enough to miss peak signal.
i'll just tie a little bag of cement to the dish.
In reality, using a snetwork of parallel-connectoed wirewound resistors in series with the motor is the best idea to drop the voltage from about 36V to, say, 30V, i.e. by about 6V -> simple Ohm's Law calculation of R = V/I where
V = 6V
I - motor current (maybe 2-3A, but I can't remember exactly)
-> R = required value of resistor in Ohms = 2-3 Ohms
But also the total resistor Wattage needs to be at least I Squared x R = 3x3x (2 or3) xat least ->18W-27W -> maybe 3x 10W resistors connected in parallel (maybe something from here) and fitted in a water-resistant enclosure.
Did something very similar when I had to drive the 24V NEC H-2-H motor (probably Jaeger anyway) of my original NEC 5000 System from the 36V o/p of the Echostar AD3000ip which replaced that Rx
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
I solved it like this, 2x15 silicon diodes each 1x15 pieces in series and the other 1x15 pieces connected anti-parallel (because of the polarity reversal) reduced by 15x0.7 volts = 10.5 volts
