Softwar patch problem
hi all,
i've got a little problem with my new software patch.
i've got a SAB 8015 DCI but no patch for it with the new T*S keys.
I've been told the Sunny 70** series shares te same SW and HW so i tried to download the patch on my SAB.
This is the error he gave me.
UPGRADE TOOL (V2.30) 22-MAR-2004 Patch
File open O.K.!
> New version binary.
-. Target loader version :L 618
-----------> Front :: 74HC164 used (connector: 14pin)
-----------> Target 2M Flash.
-----------> Target SST FLASH-2M.
Connect Success
// FileInfo: AT-7010DCI, H/W(12.01.A5), S/W(02.00.05)
// Target: L 618, u-C[0] , FLS[2M], S-8015DCIZ, H/W(12.01.A5), S/W(02.00.05)
Target Model Mismatch : S-8015DCIZ
Upgrade Fail
STB normal start.
can I change de name of this file and how ,so the program accept this patch???
Or is there another solution???
Thanks for your help
Francesco
tamazgha2003
dreambox 500s
tamazgha
no,it wont affect the file but you have to go on engineer mode by clicking the spacebar of your dektop .
1.start upgrade tool v.2.30
2.click spacebar of desktop
3. load the bin file (any binfile with the same hardware version as your receiver)
4.off and on the receiver by the rear switch
5. wait until finish
Thanks verry much it worked and i've got al the channels.
Francesco
