Splitters
SeanCorky
Technomate 1500CI+
ISS 1M Offset Dish
Moteck SG2100A Motor
Merseyside
Hello again
Im planning on being able to plug my reciever in 1 of 3 places in the house, i have 3 female f connection sockets which im going to put round the house so i can have my reciever either in my room, living room or loft.
I already have a 3 way splitter for my broadband, can this be used in my new set up or do i need a special kind ?
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Well if you bought a quad lnd you could cable up three of the outputs (and insulate the 4th) one to each location, that would be the easiest way I would have thought. Why you would think a broadband splitter (which I assume you mean a four port hub or router) would benefit you in this I totally fail to comprehend :-doh!
SeanCorky
Technomate 1500CI+
ISS 1M Offset Dish
Merseyside
Its like this
It splits the connection coming in the house from the coax
I have seen them advertised as cable/satellite
I only want to use one way at a time
Since it says 'all ports active DC' in French, it will work with the set up to take to four points in the house.
The only downside is a loss of approximately 4 dB and maybe a slope of frequency gain loss at the higher end, but if the dish is spot on then you may not notice it.
Topper
What has a four way passive cable TV splitter got to do with broadband???
Ah you are talking about broadband over NTL cable, I would not know if you could use that device at all. What frequency is it rated for???
SeanCorky
Technomate 1500CI+
ISS 1M Offset Dish
Merseyside
Yeah i mean i get broadband through cable tv, there is a splitter which splits a cable to my cable tv box and a cable to my modem
Does anyone reccomend a good splitter ?
Must be atleast 3 way
That one is maybe the best i have seen
Go for the 3 way, it will have a lower insertion loss, ethe four way splitters can cost you 8db, a three way may cut it down to 5db or so. There are active splitters around, these should give you zero loss, I think that you can get them from CPC.
I have never found a three way splitter to work more efficiently than a four way at 2GHz, no matter how its internals are designed. YOu havent shown the picture of the three way either, so I doubt very much that its got full DC continuity (Ive never seen one by the way, but passive 3dB blocks are not of equal attenuation on each link by default)
A four way is likely to be more common, and cheaper (the 2/3dB extra loss you can live with.)
Not when it's on top of a 5db loss, could well make the difference between bad weather reception and no bad weather reception, I use the three way splitters all the time and find they have a lower insertion loss. ;)
PS. Not all IFs are at 2Ghz.
mhku
TM Nano ~ sg2100
Midlands
not this kind of splitter then:
SeanCorky
Technomate 1500CI+
ISS 1M Offset Dish
Merseyside
I will buy a new one
Just need to know which one will give me the best results and i'll either go out and buy it (its its from maplin or somethin) or buy it online
Orthoclipse
Various
The one I use is a Global 4-way active splitter which I find works well - SPLIT4AF
h**p://www.globalcom.co.uk/communal/splitter4.html
spiney
Pace 2200 Sky digibox with ftv card, Comag SL65 FTA sat receiver, 40cm Sky minidish, Setpal terrestrial receiver (for free uk tv only!).
Midlands
sounds like an iffy way of doing it!
An alternative would be to to keep the receiver in one place, then use modulated UHF rf out with the Sky "eye link" system, along with a "link plus" and dc power injection. Grandata sell the whole package at around £22 (excluding SLX eye links at £5 each, and postage), for non-Sky equipment, at: www.grandata.co.uk (go "catalogue", go "audio video accessories").
If that's unacceptable, and for some reason it's better to move the receiver around, then I'd have thought a sat "line amp" should cope with any attenuation problems due to sat i.f. signal splitting. In theory, all splitter ports should be always be properly terminated, but in practice you're probably still ok. As long as it's just your dish, and you're not doing it to a sat distribution system shared with somebody else!
SeanCorky
Technomate 1500CI+
ISS 1M Offset Dish
Merseyside
At the moment i have my reciever in one place and i have a video sender, its like a sender and a reciever, both with little ariels, i can control the box in different rooms with it too
But the quality isnt good enough, i want the quality to be the same as if i was to plug the scart straight from the reciever into the TV, the way i have it set up, its not even going through one wall, its going through the glass of the conservatory and the picture is like i am watching tv through a dodgy ariel.
