star track problem
tatawinw
Likes
hello,
my 2005 super ci reciever has a with tps crypt. i can't enter any code in tps crypt that exists in my box. could anybody please help to find out the solution and to help me to enter codes in tps crypt
thanxxxxxxxxxxxx
rockchang
Likes
hp7800---perfect arion-1700 clone receiver! +
coolsat 4000pro +
pansat 2500a +
starsat sr-x200ci +
infinity usb+cas interface 2+matrix reloaded
china
#2
tatawinw said:
hello,
thanxxxxxxxxxxxx
HI, tatawinw,
the most easy way to solve it was to " load default key" ,then try to input keys again.
good luck!
Likes
star
iran
#3
hi,
dear rockchang,i think if i " load default key" i will miss my other channel and tps crypt. because tps crypt created in my reciver whit later software than factory default.plz tell me if u sure about ur order.(forgive me about my bad english)
tatawinw
Likes
rockchang said:
HI, tatawinw,
good luck!
hi rockchang,
you are simply the best of the best . it functions perfectlly. have done default keys and as ou proposed.
Iwould like to thank you very muchhhhhhhhh
tatawinw
Likes
rockchang said:
HI, tatawinw,
good luck!
hi rockchang,
tatawinw
Likes
rockchang said:
HI, tatawinw,
good luck!
hi rockchang,
you are simply the best of the best . it functions perfectlly. have done default keys and as you proposed.
