STARCOM SR-X 120 D plus - please help for TPS & MULTIVISION
Neki
Likes
Hi to all,
I have just downloaded the latest software (12.68) for my receiver found this morning on www.satsw.net hoping to have back the TPS & MULTIVISION channels but still they are not opening?? Is there anything else I should do or there is still problem with the software?
Please help. Appreciate your feed back.
NEKI
Likes
starsat receiver
#2
Neki said:
Hi to all,
NEKI
i HAVE THE SAME RECEIVER BUT NO PROBLEM
Receiver software removed. DO NOT post flashes on this forum. Follow the rules or get banned.
Neki
Likes
thanks,
..... but my receiver is 4000 CH, V7, so I downloaded the file April_20_Starcom_New_V7
and have the mentioned problem. I wonder if I can try to download the file you sent to me?? Furthermore, when I reach MULTIVISION channels my receiver goes OFF and ON by itself??
Neki
Likes
No, I cannot download into my receiver as I have the message MODEL ID IS NOT MATCHED when I try to download it. Can you suggest maybe some other website where I can find the right software for my STARCOM as the one downloaded from www.satsw.net this morning is definitely not working for TPS & MULTIVISION.
Thanks & cheers
