sragoo
On Road to.....nirvana?
- Feb 26, 2005
- Age
- 74
DB 7025 &
StarSat SR-X 200 CI Plus
- Middle Earth
hi all,
I have the following set up :
HW : StarSat 200CI+ HW version : 7
Model ID : 224
SW version : 12.69.1 (latest from satsw.net)
I noticed that while updating Nagra Keys of POLSAT(7001),
the following error occurs :
After updating the keys read like this:
00 : AA XX XX XX XX XX XX XX
01 : YY XX XX XX XX XX XX XX
and the channels disappear.
I noticed that the actual value of the key AA should be
AA + 1 and YY actually YY + 1 (ie if both keys change)
eg. if your STB updated it to 45, then actually it should
be 46. (I manually made the change and it works fine)
If you have this problem, use your calculator in HEX mode,
add 1 to values of AA and YY and manually input the results
and it should work till this is fixed. It worked for me so am
sharing this tip with everyone.
I feel that this could be a bug in the firmware and through
this forum would appeal to the developers(satsw.net) to kindly consider
fixing this in the next firmware version.
TIA,
SRAGOO
Model ID : 224
TIA,
SRAGOO
