starsat Receiver SR-X200CI plus VIACCESS Help
L
life_lb
Likes
Hi
#1
Hey Pro,
I am a new to this and this is my first thread.
I have starsat Receiver SR-X200CI plus with Orange Zeta CAM and AGL FunCard (Open Platform).I installed NEW_Loader_for SR-X120_130_150_200CI.zip then i upgraded the Firmware using April_29_SR-X200CI after cleaning it with sw_ver_clean_for_SR-X120,150,200CI.The STB status shows Model ID E224, H/W Version 2.00 and the S/W Version is 12.69.Then using the dreamloader.exe, i tried to upload the HEX file April_24_key_120_130_150_200CI.hex.It gives me Uploaded successful But the channels are still locked...Even I tried to check the codes by pressing 1234 on the STB menu, either they are no data available or the codes are 0s.I tried to enter the code manully, also locked. I have noticed that most of the codes have Channel id(6 digits ex: AB SAT 00 70 00) but my receiver accepts only (5 digits).
I have alot of questions..:)
1- what is the use of these files(April_23_softcam_key_bin and SR-X200CIPULS5518(SST39VF160)).
2- What about the channel ID how can use 5 digits instead of 6 digits.
3- After transfering the HEx file, THe Hex codes should be shown in the STB??
4- Is there any relation between these HEx codes and teh CAM AND FUncard?
5-The Hex Codes are for the receiver or for the CAM or FUncard??
6- the CAM can be updated using PCMCIA interface in a laptop and if yes what is the procedure?
I really need your expertise to fulfill my thought.
So last important question is WHAT SHALL I DO?.
Thx Guys
N
nbtr20
Likes
eutelsat w3
windows xp proff
#3
1-there is no relation between the hex file and the cam.
2-the relation is between the software and the ex: tps+art you need 12.68 or12.69 versions to download go to http//www.satdw.com
L
life_lb
Likes
Hi
#4
Guys, Thanks for your reply, But i am have some inquiries if can help me.
1- Is it possible to configure my cam (Orange Zeta CAM ) using a laptop?
2- Do u think This Type of Cam can be configured to receive s_x*TV channels or Pink or Showtime or....
Thx guys.
R
RAMSESS
Likes
male-accountant--electronics
#5
With The Soft 1269 For The Astra And Starsat Familly The Codes Changed
From The Extensions From Softcam.keys To Softcam.bin
So Dont Use Dreamloader But Only Use Emupgrade To Send The Keys.
D
dishmetren
Likes
good luck
#6
use EMUpgrade to download this keys
http://www.satsw.net/upload/upgrade224.zip
Attachment removed. DO NOT post anything that contains keys on this forum. follow our rules or risk a ban from the forum
:-rules
W
ward
Likes
i am a men from lebanon
#7
hi
i have a star sat sr-X200CIplus before i tooked to a market they upgrade and it was open multivision and xxl
now is open only xxl without multivision
i tryed to make upgrade but i dont know where can i find emupgrade
what is the procedure for that?
advise plssssss
