kh900s
my love to lazio
- Aug 25, 2005
- Age
- 48
starsat sr X 3500 cuci ultra
pc contain motherboard ASUS free pentiume 4 (2400 MHZ)
- north africa
cuteboy1 said:HI,
Lets take ur questions 1 by 1 ,
3500 CUCI comes in 2 versions, check ur receiver and if it says 3500 cuci plus then it has 1 MB RAM if its 3500 cuci super then its 2 MB RAM so use the correct file with 1 M or 2m.
Next the cable, the standard cable will not work make sure U have a cable which has only 3 pins connected 2,3 & 5, pin 2 & 3 should be twisted means pin 2 from one side should be connected to pin 3 of other side and same should be done for the pin 2 of other side also, pin 5 connected directly to pin 5 on other end.
Step by step instruction available on the same website I told U before, there is a file there "How to use eMUpgrade" download it and read it and U will know what to do.
Sites from where U can find keys are
www.rdi-sat.com
http://byksat.kabel1.cz/
http://www.luxsat.be/
Look for the keys for TPS Package on these sites and enter the latest keys
Lastly U forgot to ask how to enter keys in the receiver
select MENU on ur remote then INSTALLATION then INPUT CODE then VIACCESS then TPS and then enter the keys
Hope it helps
thank you very match cuteboy1 because your information that good for me
especially that the standerd cable don't work
