Strange problem help required
I
in_msz
c and ku band setups
India
Hi
Iam from India .I installed a 6 ft antenna for 83 deg east which is my country satellite whose eirp is 42 db at my place. The strange problem is i cannot lock the channels .Even from other satellite also i cannot lock it.
I can lock the ku band channels with a ku band lnb.
i crosschecked the Receiver at my friends place who lives in neighborhood its working fine.
I cant doubt on cables as ku is working fine.
My doubt is on Lnb its universal c band lnb 13k with gain of 65 db
Somebody told me that 13k lnbs are not suitable for the reception.
Is it true please guide me
Regards
D
dspdsp
DishTV DTH
Zenega 1004s Receiver
90cm offset Sharp dish antenna
india
Best way is to get your C Band LNB tested by replacing working LNB with yours at the some friend's C Band setup. Or members is there any other way to test it with Multimeter please help.
Vipersan
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
in_msz said:
Hi
Regards
Hi friend ...
I don't wish to presume you haven't set up for c band before ...but just making sure you have tried the obvious ..
You are using an IF frequency of 5150 during setup ?
rgds
VS
Vipersan
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
...Hello again ..
I've just checked Lyngsat regarding C band reception on 83 degrees East..
All transponders are Horizontal or Vertically polarized ...so NO circular polarisation ..
So ..a standard H/V switching LNB such as the Pauxis will do the hob just fine ..
It does however ...not require the use of a dielectric plate in place ...so if one is fitted in the lnb throat (waveguide) ..it should be removed before scanning for channels..
What sort of lnb are you using ?
If a plate _is_ fitted it will reduce any signal received to unusable levels.
A description of your feed / lnb(f) and any other hardware fitted at the dishes focus would help ..
rgds
VS
