Strongest / Reference Transponders
iceburn
ok here is (not necessarily the strongest but ones I do pick up very clear and if ppl remember problems I had with my system it is saying something :-))
(Does help to put location, Swansea, South Wales) will update list when I go through and see which is strongest and weakest.
42E 10.968V 86% strength 69% quality
39E 12.524V 93% / 73%
28.2E 10.803H 97% / 79%
16E 11.449H 96% / 82%
13E 11.131V 93% / 85%
7E 11.491V 94% / 72%
5E 12.073H 95% / 79%
1W 11.420H 93% / 76%
4W 10.743H 87% / 64% (slight breakup)
4W 10.762H 97% / 19% (don't get anything god knows why!)
5W 11.591V 97% / 86%
8W 11.555H 95% / 72%
12.5W 11.389H 86% / 71%
15W 11.150H 92% / 72%
22W 11.630H 85% / 66%
30W 11.731H 94% 72%
system is now Lidl crap cable, Technomate 1500CI super, .7dbLNB, Motorise .88m Traix sat dish.
rossy
Skybox f3 spiderbox died hd9000 technomate 1500ci+, skystar2,1.1m dish .3db bluline lnb,Sky,
Span 58W to 42e with trees bare! 42e gone and now 39e
southern england, Berkshire
The reason you are getting nothing is that its not picking up any signal. The TM 1500 does that often on a Freq where there is no signal and it shows a high signal strenght but it probably is staying red on screen and also giving 19% quality in red also. Theres actually no signal but the TM shows it that way. On the other 4w you also say some slight breakup at 64%. The TM seems to have a threshold of pic/no pic in the low to mid 60's
Cheers
tesla
www.bloka.com
Lost in the night
Is it necessary to know the strongest transpoder for every orbital position?
Every orbital position may have several beams. It is there any great difference between the strongest and the weakest transpoder? I don't think that there is any significant difference.
Furthermore, if the transpoder is out of order at the installation time? Imagine that there is a heavy rain (or a thick cloud) over the uplink station of the strongest transpoder. How can anyone manage to find the satellite?
The thread is designed for those who may not be aware which transponders to set on their receiver when aligning their dish, we have had hundreds of posts from members experienceing problems with finding a satellite and very often it is because their receiver has defaulted to an inactive or out of footprint transponder. In an ideal world we would have a list for each of the different areas, as what you can definitely see in Greece, may not be seen from the UK with similar dish size. :)
We have also endeavoured to find transponders which have FTA offerings where possible and higher symbol rates for more robust reception.
Leee
Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
47°N/8°E/490m
strongest transponders
I've added that because my search for the strongest transponders across certain satellites made me have to search more than I should!
guest poster
registered
STRONGEST TP/ Channels (MID UK 75e-74w KU Band) LIST UPDATE 06/06/08
These are the strongest Channel/ transponder lists per satellite 75e-74w from the centre of the UK as recorded on one average sample system in mid UK 1.1m Triax/ TMS1000/ Sharp .3 lnbf. 30m cable. Busy in line of sight horizon to horizon limited at 45e 45w plus estimated with a small dish from a vanatage point beyond 45e/w- extreme east estinmated only! Some channels blank but still give signal.
SAT_____Freq____H/V______S R____CH Name______________Strength____Quality____NOTES
75e_____12548___V_______22000______________________________(v extreme se only)
72e_____12518___V_______2500____E-TV____________________61%_____69%___ se only
70.5e___11214___H_______13021___Euronews 70.5e__________50%_____63%____
68.5____12562___H_______26657___Press TV________________51%_____66%____
62e_____11104___H________3328___VTV_____________________51%_____65%
60e_____11101___v________4105___Bashkir_________________45%_____52%_____??
57e_____12551___v________9404___BTV_____________________52%_____69%_____
53e_____11616___V________2894___Al Libiya TV____________61%______82%_____
------------<<<<<-Building/ roof line->>>>>>-----<<<<estimated below 45e-
45e_____11511___v________2894___Southern Sudan T.C._______76%______97%___
42e_____11804___v_______24444___CNN TURK________________70%______83%_____
39e_____12524___v_______30000___KAI_____________________75%______91%_____
36e_____12532___h________4340___AZTV____________________65%______75%_____
33e_____11596___v_______27500___MAP TV__________________72%_____85%_____
28.2e___12460___h_______27500___Portal v 7______________79%_____97%_____
26e_____12181___h_______16200___SHEBA___________________66%_____86%_____(1st)
26e_____12073___h_______27500___EuroNews________________65%_____83%_____(2nd)
26e_____11862___v_______27500___Arab Tourism____________62%_____80%_____(3rd)
23.5e___11916___h_______27500___TV Rijnnd_______________76%_____97%_____
21.6e___11530___v_______2857____AL RAI__________________53%_____56%_____<< NEW >>
19.2e___11538___v_______27500___France 26 19e___________74%_____94%_____
16e_____12540___v_______4340____B.N. Srp________________76%_____92%_____
13e_____11034___v_______27500___Al Jazeera______________74%_____95%_____
10e_____11160___h_______2170____Adjara__________________69%_____86%_____
9e______11958___v_______27500___Poker Ch________________75%_____90%_____
7e______11283___v_______27500___M6 Ssc__________________73%_____88%_____
5e______12073___h_______27500___Inter+__________________74%_____93%_____
0------------------------------------------------------------------------
.8w_____11229___h_______24500___Poker Channel___________74%_____89%_____
4w______10722___H_______27500___??______________________48%_____50%_____
5w______11591___v_______20000___France 2________________75%_____92%_____
7w______11862___v_______27500___City 7__________________51%_____56%_____
8w______12649___v_______27500___KK______________________76%_____91%_____
11w_____11515___v_______7789____ATV_____________________52%_____57%_____
12.5w___11387___v_______27500___Bethel__________________72%_____85%_____
15w_____12608___h_______19279___MAC TV__________________76%_____95%_____
18w_____11673___h_______28571___NBA TV__________________69%_____82%_____
22w_____12735___h_______16640___A3______________________72%_____88%_____
24.5w___11674___v_______27500___Channel S_______________73%_____86%_____
27.5w___11517___v_______5632____NBA/Intelsat____________72%_____88%_____
30w_____12012___v_______27500___BBC World 30w___________76%_____93%_____
31.5w___11504___v_______1600____One TV__________________73%_____84%_____
34.5w___10969___v_______20000___AV1_____________________65%_____75%_____
43w_____12651___h_______30800___Fox Sports______________69%_____82%_____
45w_____11510___h_______26894___CCTV 4__________________64%_____74%_____
-----------------------------------------------Building/ roof line-------
<<<<estimated below 45w>>>>>>
58w_____11612___h_______3670___Cubavision 58w___________63%____69%_____
Strongest transponder's with fta tv
Latest update for January 2009 {<<< = new data}
East Satellites~~~~~~~FTA where possible~~~~~~~
45 east IS-12-----------------11500V 4340 Racing International {No fta}
42 ----Turksat 3A------------12679V 8888 24 TV,<<<
40 ----Express AM-1-------11098H 4800 Uzbekistan tv,.
39-----Hellasat-2-------------12523H 30000 The Voice,<<<
36-----Sesat-------------------11639V 2170 Al-Iraqia Atv AF,<<<
33-----Eurobird-3-------------12739V 12402 Zdrave,<<<
31.5---Astra-5A -------------11766H 22000 Astra Vision
31 ----Turksat 1C -----------10994V 2222 Tempo-Turk,<<<
28.5 --Eurobird-1------------11681V 27500 Aljazeera English,<<<
28.2 ---Astra-2D ------------10729V 22000 More 4 UK,<<<
26 -----Badr-4 ----------------12149H 27500 Safa TV,<<<
23.5 ---Astra 1E-------------10862H 22000 Ocko,
21.6 -- Eutel W-6 -----------11531V 2857 Al RAI 1B
19.2 - Astra 1L -------------11597V 22000 BBC World,<<<
16 -----Eutel W-2 -----------12656V 4883 TV Shqiptar Satelit,<<<
13 ---- Hotbird-6 ------------12597V 27500 BBC World News
10 -----Eutel W-1 -----------11160H 2170 Adjara-tv,<<<
9 ------Eurobird-9 -----------11804V 27500 MelodyZen tv,<<<
7 ------Eutel W3A ----------11451V 25066 Digi Turk,<<<
5-------Thor-2 -----------------11247V 23149 Kanal Lokal,
4.8-----Sirius-4 --------------11766H 27500 Novy channel
4 ------Eurobird-4 -----------12539H 39064 data feed,<<<
West Satellites,
0.8 W --Thor-5 ---------------11785H 28000 1 Music,<<<
0.8 ----Thor-3 -----------------12399H 28000 Musiq1,<<<
1.0 ---- Intel 10-02 ----------12687H 27500 OTV,
4 ------Amos-2 ----------------10757H 27500 MTV Ukraine
5 -----Atlantic-3 ---------------11590V 20000 France 2
7 -----Nilesat 101 ------------11862V 27500 City 7 tv,
8------Atlantic-2 --------------10974V 27500 Al Jazeera English,
11 -----Express 3A -----------{currently there is no active transponder},<<<
12.5 --Atlantic-1 -------------12655H 4285 Record News Int
15 ---Telstar-12 --------------12608H 19279 VOA Persian,
18 ----Intel 901 --------------11569H 5773 A2 Macedonia,<<<
22 ---- NSS-7-----------------11488H 2170 STV-USA
24.5 ---Intel 905 -------------11675V 27500 NTA,
27.5 ---Intel 907 -------------11665V 13020 Five UK {encrypted}
30 ----Hispasat 1C----------12012V 27500 BBC World,<<<
30 ----Hispasat 1D----------11474H 3400 TV Canaria,
31.5 -- Intel 801 ------------{currently there is no active transponder}<<<
34.5 -- Intel 903 ------------11473V 2480 data feed
43.1--- IS-3R ----------------12650H 30800 EWTN,
45.1 ---IS-1R ----------------11510H 26694 CCTV-F,
58 -----IS-9 -------------------11477H 26463 BT Tower A (feeds)
guest poster
registered
Thanks william for taking the time to do an update... have you any signal/ quality or meter data. Thanks.
No but I may include meter readings in the next update in April 2009 after these satellites are fully in service:-
Astra 1M for 19.2 east,14 transponders working currently,
Hotbird 9 & 10 for 13 east,
Eutelsat W2A for 10 east,
Express AM44 for 11 west,
Telstar 11N for 37.5 west,
guest poster
registered
OK, it does help some if they try to get a weak satellite with the wrong dish size.
Ratchet
Falkirk
TM 5402(M2), TBS 6983, Sky+ HD, Stab USALS HH100, Faval 1M, Triax TD54, Hauppauge HD PVR
Falkirk
Here are my experiences with strongest signals per satellite using my Passion HD box and 90cm dish.
Sat Freq Pol S/R Channel Srength Quality
45.0E 11591 V 30000 Discovery 69% 95%
42.0E 11804 V 24444 TNT 68% 100%
40.0E 11096 H 4800 FORUM-TV 71% 83%
39.0E 12729 V 30000 Etno 72% 93%
36.0E 12548 H 2730 Medi1SAT 73% 80%
33.0E 11596 V 27500 MAP TV 70% 85%
31.0E 11012 V 2150 AKSU TV 75% 65%
28.2E Various at 70% / 100%
26.0E 12182 H 16200 YEMEN 71% 61%
23.5E 11914 H 27500 TV Noord 67% 100%
21.6E 11617 V 27500 Radio Euronics 72% 60%
19.2E Various at 70% / 100%
16.0E 11303 V 30000 Foklor TV 69% 92%
13.0E 11200 V 27500 EBC.1 68% 100%
10.0E 12631 V 8888 AP Feed 75% 79%
9.0E 12054 H 27500 Tu Tele Local 69% 90%
7.0E 11451 V 25066 Digi Promo 69% 92%
4.8E 11727 V 27500 TV2 Zulu 70% 60% (Nordic)
4.8E 12418 H 27500 Bookie Feeds 68% 100% (Euro)
4.0E 12536 H 39064 Data 70% 96%
1.0W 12418 V 28000 Poker Channel 68% 100%
5.0W 12543 H 27500 MCM Belgique 70% 98%
8.0W 12649 V 27500 Kabelkiosk 69% 99%
12.5W 11355 H 11781 RAJ CO 74% 74%
15.0W 11060 H 19279 E! EMEA 70% 84%
18.0W 11605 H 8500 Data 75% 75%
22.0W 11563 H 6111 CNN Feed 74% 86%
24.0W 11048 H 14400 TV Agro 73% 86% (DVB-S2)
27.5W 11665 V 13020 Ch5 UK 74% 87%
30.0W 12149 V 27500 Canal 24H 67% 100%
34.5W 11474 V 2480 Data 70% 76%
43.1W 12659 V 28670 Buzz 72% 56%
45.0W 11510 H 26694 CCTV4 71% 66%
FYI the Passion locks a signal at 50% quality and gives good rain fade margin at 60%.
Ratchet
Falkirk
Falkirk
Update:
33.0E 11093 H 1429 Hayat TV 73% 96%
Never seen a signal that strong from 33.0E before.
sonnetpete
wordpress.com
Normandy, France
Having recently moved the Triax onto a perfectly vertical pole and tinkered a lot (!)? I now feel confident enough to list the following list, compiled between 15:00 and 17:00 on a clear afternoon:
-Pos------TP-------Channel------S/Q
45°E---11618V---Prima--------62/77
42°E---11096V---Powerturk ---69/84
40°E---11097V---UZTV 1-------68/79
39°E---12524H---The Voice----69/84
36°E---12547H---Medi1 Sat----60/81
33°E---11165V---Rete Oro-----65/80
31°E---11009V---Aksu TV------61/68
28.2°E-12207V---Sky News----76/97
26°E---12253H---KTV Ch1------66/59
23.5°E-10863H---Ocko TV------75/96
19.2°E-10818V---TVV Int-------75/96
16°E---11304V---Folklor TV----71/75
13°E---10796V---Tele 5--------73/96
10°E---11747V---BLU----------67/65
-9°E---11804V---C-Music------73/86
-7°E---11345H---TPAI---------69/86
4.8°E--11766H----Novy Ch-----71/85
0.8°W--12418V---Poker Ch-----67/95
-4°W---10759H---Kiev STB-----68/53
-5°W---11591V---France 3-----69/86
-7°W---11862V---City 7--------67/55
--""----12303H----FM----------62/41
-8°W---12649H---Kabel Kiosk--68/88
12.5°W-12720V---Puglia Ch----64/81
-15°W--12608H---BBC Persian-63/72
-22°W--12735H---TV Coran----53/67
24.5°W-11025V---One TV------63/55
----------------TREE LINE----------
I can get quite a few horizontals on 7W up to 48Q but after 10pm. Still watchable though and most verticals during the day unless it rains!! Hope this is useful, though please remember that I'm a bit further south than the UK in relation to certain footprints.
Pete
wod
yorkshire
found these quite good when i was redoing my dish on the west satellites, so add to the current list
18----Intel 901 --------------11605H 8500 data
22 ---- NSS-7-----------------12603H 40000
11563 H 6111 cnn news
24.5 ---Intel 905 --------------11025V 1476
11675V 27500 NTA,
Thundery
VU+ Duo, Orbital 80cm Dish, Technomate TM-2300 Motor.
Cheshire, UK
My Reference Transponders: NW England. NE Cheshire.
These are some excellent transponders found using a dreambox 500s,
an 80cm orbital dish, and low noise Golden Interstar lnb.
Sat Freq Pol S/R
42.0E 11804 V 24444
39.0E 12524 V 30000
36.0E 12686 V 04340
33.0E 11513 H 30000
28.5E 11681 V 27500
23.5E 11992 H 27500
19.2E 11597 V 22000
16.0E 11554 V 30000
13.0E 11862 H 27500
7.0E 11513 H 27500
4.8E 12305 H 25547
1.0W 11403 V 24500
Thundery
Cheshire, UK
Sat Freq Pol S/R
42.0E 11804 V 24444
39.0E 12524 V 30000
36.0E 12686 V 04340
33.0E 11513 H 30000
28.5E 10729 V 22000
23.5E 11992 H 27500
19.2E 11597 V 22000
16.0E 11554 V 30000
13.0E 11862 H 27500
7.0E 11513 H 27500
4.8E 12305 H 25547
1W 11325 H 24500
sonnetpete
wordpress.com
Normandy, France
I haven't posted anything on this thread since I changed my dish to a Gibertini 1M and receiver to a Vantage. Also, I've been re aligning and trying to get everything as spot on as I can. The Vantage usually locks a signal at around 70Q reading.
So, here is my transponder list, compiled on an afternoon with some cloud cover. Please note my location which may affect some of the fringe reception reports.
4.8°E Rada.......11766H 91S/93Q
..7°E M6 Suisse.11283V 92S/93Q
..9°E ANN.........11727V 91S/91Q
.10°E ANB.........11144H 91S/86Q
.13°E SLOTV2... 12520V 78S/99Q
.16°E Folk+.......11283H 91S/82Q
19.2°E Direct8...11538V 92S/94Q
23.5°E 0cko......12168V 92S/92Q
..26°E Pinoy TV..12245V 91S/73Q
..28°E BBC2 Eng.10773H 93S/90Q
31.3°E Hayat.....11026V 91S/94Q
33°E MAP TV.....11596V 90S/83Q
36°E Lider TV.....12521H 89S/76Q
39°E Teleasty....12756H 91S/91Q
40°E NNTV........11676H 91S/75Q
42°E Avrupa......11743V 90S/85Q
45°E Prima........11686V 90S/92Q
53°E Belarus TV.11161V 89S/73Q
57°E Asia TV.....11182V 89S/71Q
0.8°W Musiq 1...12418V 92S/93Q
..1°W Speranta.12563V 92S/91Q
..4°W OTV.......10722H 90S/77Q
..5°W France2..11591V 92S/91Q
..7°W City7......11977V 89S/79Q
..7°W FM.........12303H 89S/74Q
..8°W Oscar.....11106H 90S/92Q
12.5°W La7......12515H 90S/90Q
15°W MSNBC....11531H 90S/87Q
18°W A2..........11588H 89S/71Q
22°W A3..........12735H 86S/71Q
I can't get further than 22°W because of tree growth. There may be slightly more performance to be had with extra fine tuning, but the elevation adjustment on the Gibi isn't engineered for small increments. I have a mod in mind for that though......
sonnetpete
wordpress.com
Normandy, France
Just thought I'd add some HD transponders. These are all FTA at the moment
42°E....TRT HD.........11040V DVBS2 76S/99Q
28°E....BBC HD.........10847V DVBS 93S/92Q
23.5°E.Dance TV......12032H DVBS2 76S/99Q
19.2°E.Servus TV.....11302H DVBS2 77S/99Q
9°E.....3DV Promo.....12054H DVBS2 77S/99Q
0.8°W..Duna1 HD......12341V DVBS 93S/95Q
Obviously these are very strong transponders, I haven't as yet managed to consistently capture any HD transmissions from 26°E or 7°W (I wish).
Though it tends to be within the eye of the beholder, for picture quality the TRT promo on Turksat is excellent.
john_graydon
Azbox premium HD+,Dusty Dreambox 7000s,&amp; Sky HD.
Dublin....Ireland
Thanks for the updates, My motor had its day and Just putting up new one. Hope everything goes ok, at least a bit of experience setting up.
sonnetpete
wordpress.com
Normandy, France
Just managed to get this one :
26°E....Al Kass HD.....12245V DVBS 91S/73Q
