Technomate 6800 - No sound on HD
perry266
Technomate 1500 C1
1.3M dish (offset) in Menorca.
Technomate 6800 HD
90cm motorised dish (offset) in Essex
Essex UK and Menorca, Balearics.
I've just installed the 6800 and it performs superbly for SD channels (pics and sound) but when I view HD channels (on Astra 28.2E) the picture is there but no sound. What do I need to do?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
Try selecting a different audio track, see if that fixes it.:)
spartans
Triax 1.1mtr cryptic H-H Technomate 6900 technomate 6900super TM9100(UR18 image) eagle (v5 image)
north east england
I think you need to select pcm in the audio options ?
iwol
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
hi perry what size tv you using please
perry266
Technomate 1500 C1
Technomate 6800 HD
Panasonic Plasma 42" HD (1920 X 1080) - and it's superb!!!!
perry266
Technomate 1500 C1
Technomate 6800 HD
I'll try that, it's set to Dolby at the moment.
What does PCM stand for? Is that the TX standard for Freesat HD?
iwol
satlook micro
yorkshire
thanks perry is that both hd and sd
pcm=In the digital domain, PCM (Pulse Code Modulation) is the most straightforward mechanism to store audio. The analog audio is sampled in accordance with the Nyquest theorem and the individual samples are stored sequentially in binary format.
The wave file is the most common format for storing PCM data. But, before you dig into the internals of wave files, it would help to get some insights to the Interchange Format Files that form the basis for the wave file format.
perry266
Technomate 1500 C1
Technomate 6800 HD
Yes, the 6800 is both HD and SD (MPEG2 and MPEG4).
Selecting PCM in the Audio menu solved the sound problem.
Thanks.
