Test Card Sky in Cyprus
Likes
2.7m diah invacom 031 quad lnb pansonic 30 and Pace 460 boxes
Cyprus
#1
Is it possible to get the sky or any other good quality test card in Cyprus? I'd like an audio test tone as well.:)
Topper
Amo Amas Amant Admin
Likes
3,309
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Why would you want that surely just tune in to a strong transponder? with digital you either can receive it or you cannot, why would anyone want to waste transponder space with a test card and signal for a service beamed primarily at the UK?
Zorba
aka Skyman
Likes
7
3m(28.2E),1.5m(19.2E.13E,10E),1m (4W ,7W)1m (?).diseqc 10,sky plus,VU+,telergy iptv.
Satlook nit colour + Horizon hdsm.
Limassol, Sunny Cyprus
#3
Actually sky did transmit an analogue frequency with a test card when they first started,but no analogue transmission now.You could try one of those cheap satfinders which have a dial display and an audio output for fine tuning,or an expensive digital sat meter like mine.:)
Likes
1,285
#4
Bloody hell zorba, that's going back a bit. :)
Was working for them at the time and the main reason was that most of the installers still only had old Maspro analogue meters when they launched, so could find it more easily, in fact some only had the little promax swinging needle meters and had to connect up the cable and receiver, before installing the dish. :-lmao Those were the days. ;)
Zorba
aka Skyman
Likes
7
#5
It wasn't so hard in those days,i am still using my promax analogue tv/sat spectrum analyser with tv picture.i could tune in and get that test card for accurate aligning.
By the way you could end an argument i had today.What year did sky digital start?
Likes
1,285
#6
As far as I remember it was Autumn 1998, with a few test prior to that.:)
Likes
Cyprus
#7
Why not; it's the only way I have of checking my plasma and the quality of the audio output - much of it is very poor until you mess around with the dac inside.:cool:
Topper
Likes
3,309
#8
In that case you are out of luck then
Zorba
aka Skyman
Likes
7
#9
What make is your plasm?Is the picture okay?you might be better off connecting your digibox to a hi fi system of some sort.
Likes
Cyprus
#10
That is the point; the Pace 430 sounds aweful; the Pace 2600 better when connected to a hifi system. But taking the output from the dac or digital from the router/MPEG chip improves quality a lot. However, the only way of testing these is to have a low distortion audio test tone.
The Pace 430 actually uses an obsolete STi MPEG chip with no published pin information.
