vjekob
- Jan 30, 2017
- Age
- 63
- 4lnbs + multiswitch
- Croatia
I have 4 quattro LNBs + multiswitch satellite setup. The distance from the antenna to the
multiswitch in cellar is approx. 15m and then the cables are run throughout the house to each
room.The problem is that however good I try to setup the satellite, I just can't get a good
enough result and the reception at each receiver is not the same (can't pick up some channels
- may be due to different receivers). Anyway, I need to do a thorough check of everything
(cabling/wall outlets etc.). Could someone please indicate what test equipment and
procedures would be used to make such a test (I have an electronics background/but haven't
worked in the area for a long time, but could get a hold of test equipment and do the
testing).
testing).
